Question about Homelite Garden
In the process of replacing the throttle cable on a Homelite backpack leaf blower when I took the trigger housing apart a black plastic return spring fell out and I cannot figure out just how the hell it goes back in. I need a diagram.
    Top Expert:
  • Homelite Master
  • 55,370 Answers
Request an assembly diagram from Homelite. Be sure to specify model.
Posted on Aug 09, 2018
Anonymous
SOURCE:
Anonymous
SOURCE: homelite 26bp backpack won't run up to full throttle
I have let my leaf blower run and warm up before throttling up and still it bogs down and shuts down. There is no air cleaner to clean should I just blow out the carb. and fuel lines?
It runs and idles just no high speed to blow.
Posted on May 09, 2009
josh1111
  • 398 Answers
SOURCE: homelite Backpacker II leaf blower start fine then
have you checked air filter? the carb may need adjusting. locate the adjustment screw(s) , screw them all the way in then back out 1-1/2 turns. try to start the engine. then let me know what happens.
Posted on May 17, 2009
Garry Clelland
  • 251 Answers
SOURCE: How do I adjust needle valves on a 25cc Homelite
Set the lowend & highend needles to about 1 3/4 to 2 turns each. Choke the carb or prime it, until the carb is wet. Fire up the engine and let it warm up. Let's set the topend first since it's the easier of the two. Go to full throttle. Adjust the topend needle for peak RPM. Leave it wide open for about a minute to see if it changes any. Should the engine go lean, open the lowend needle slightly, if this dosen't work... you will have to adjust the needle valve inside the carb.( I will explain this later) If the topend runs OK, then slowly pull the throttle down until the engine begins to "four cycle" hold the throttle there. Adjust the lowend needle until the "four cycling" barely stops. Now lower the throttle more until it "four cycles" again, and adjust the lowend again. Keep doing this until you reach full idle. Now, from full idle begin to throttle up until the engine starts to bog or hesitate. Open up the lowend needle just enough to eliminate the bog or hesitation.
http://tech.flygsw.org/walbro_tuneup.htm
hope this helps :)
if it does please vote
Posted on Oct 23, 2009
Anonymous
  • 437 Answers
SOURCE: My Homelite backpack leaf blower only idles. when
Is the new gas some you just mixed up from the gas station or is from the can in the garage? If it is indeed fresh then you are looking at needing the carburetor adjusted. Sorry you can not do it yourself, The epa only allows qualified technician to adjust them. Plus the tool to do so are not available to the general public.
HTH
Good Day.
Posted on Oct 31, 2009
wfay
  • 13 Answers
SOURCE: need diagram to reinstall tranny fell apart when for dc988
http://www.ereplacementparts.com/
Try this place, one of the sites I use for documentation.
Posted on Nov 27, 2009
I have no throttle control.
The spring will probably be intended to return the throttle to the idle position when the trigger is released. There should be drilled holes or notched tabs that the spring will connect to. When the trigger is in the idle position, the connecting points should be just a bit farther apart than the length of the spring.
Jan 01, 2016 | Garden
Backpack II. How do I replace the primer bulb?
  1. Homelite Blower UT08072 User's Guide ' ManualsOnline.com
    lawnandgarden.manualsonline.com > ... > Homelite Blower OPERATOR'S MANUAL. BACKPACKER II. UT08072 and UT08572. SAVE THISMANUAL FOR FUTURE REFERENCE. Your blower has been engineered and ...
Jul 20, 2015 | Homelite Garden
How to adjust my throttle cable on my backpack blower br 550 sthil
the cable has streched out
you may need to shorten it to get an adjustment range
you could always look up the manual
it tells you how to do this in it
Nov 30, 2013 | Stihl Br 500 550 600 Backpack Blower...
Throttle handle trigger is stuck
see if the linkage on the carburetor is stuck
Nov 18, 2013 | Echo Backpack Blower PB-500T
Throttle trigger does not retract
Item 6 on the plan are spring washers, i cannot see any other tension springs that control the retraction of the trigger. Hope this helps you.3_2_2013_11_20_49_pm.jpg
Jan 06, 2013 | Stihl BR400 Backpack Leaf Blower
Broken pull cord
How to replace a broken pull cord on a leaf blower.
1) Remove Hex bolts holding plastic leaf blower housing in place with your hex wrench. you may want to cut the cord with scissors and loosen the bolt or screw securing the rope assemble with hex wrench or screwdriver.
2) Remove spring assembly Carefully. (DO NOT REMOVE THE SPRING ONLY REMOVE THE ASSEMBLY)
3) Remove old cord. Notice the direction the pull cord is wound. This is important in the following step
4) Wind new pull cord in the same direction you removed it, as in step 3, Make sure cord secures in the slot provided on pull and assembly.
5) Replace the pull cord pulley and place over spring.(This is the white plastic spool.)
6) Rotate the pull cord assembly 2 or 3 times in the same direction the cord pulls. (wearing safety goggles and work gloves) Reinsert the center screw by securing in in place with your screwdriver.
7) Insert the leaf blower cord into the end of the handle opening. Secure the handle by tying a knot at the bottom of the new cord.
8) Place the pull cord assembly back onto your blower in its designated area then secure by refastening the 4 hex nuts.
9) Replace the housing cover of blower and refasten the hex nuts.(the housing you removed in step 1.)
I hope this was some help to you. Good luck.
Jul 01, 2012 | Homelite Consumer Products Backpack...
Throttle trigger cable
it can be repaired, but you must order the new part from the manufacturer. . .i'd get a new one
Apr 20, 2010 | Homelite 'Yard Broom' Leaf Blower
Husqvarna 155bt Gas Backpack Leaf Blower throttle adjuster does not hold throttle down. just spins.
Do you mean the throttle lock? It is a basic mechanical lock. If it just spins I would assume that a chunk of plastic has broke off or the lever is misplaced. Take the throttle housing apart and identify the problem. New parts are available from your local Husqvarna dealer.
Nov 25, 2009 | Husqvarna 155bt Gas Backpack Leaf Blower
Homelite 26bp backpack won't run up to full throttle
Nov 16, 2008 | Homelite Consumer Products Backpack...
Garden Logo
83 people viewed this question
Top Homelite Garden Experts
roeb
Randy Schumann
Randy Schumann
Joseph Mueller
Joseph Mueller
Are you a Homelite Garden Expert? Answer questions, earn points and help others
