To set up a speed dial option, make sure that the phone system is in standby (no handsets in use). Make sure that the number you want to have as a Speed Dial number is in the Directory. You can type in the number (up to 30 digits) and then press Select (shared key with Menu to the upper right of the arrow keys). Alternatively press Menu and use the up/down arrows to navigate to Directory. Press Menu/Select twice. Type in the phone number. Press Select to move to adding a name with the number key. Press Select to Save. You can also add a number from the Redial list. See the abbreviated manual on page 7. Press Off/Cancel to return to the previous menu list. Press and hold Off to exit the menu system completely.
Now, press Menu (if you aren't in the menu) and use the up/down arrows to navigate to Directory. Press Select. Scroll to Speed Dial and press Select. Select a speed dial location and press Select. Scroll through the directory list and press Select when the correct entry is highlighted. Press and hold the Speed Dial number (0 or 2-9) to dial this number. See page 8 of the manual.
The abbreviated manual for the CS6629, CS6629-2, etc is available here: https://phones.vtechcanada.com/media/document2/products/%7B76B9FBDF-8471-4E06-BE52-B0E8A258E5F8%7D/CS6629-3_CAAUM_3_912.pdf .
I hope this helps.
SOURCE: speed dial
For System Speed dial, you can only do it from a port with Attendant Features. Typically they are ports 1 and 2.
Assuming they are still the default settings, the available System Speed Dial bins are 00 thru 79.
from one of the Attendant Ports:
Press Feature
Press Redial
Dial in the memory location bin number (00-79)
Press "9" for the Trunk Access Code (or whatever it is)
Dial in the Phone Number (24 digits max)
Press Feature
To use, get DialTone, press Redial, enter bin number (00-79)
SOURCE: Problem when dialing phone
Yes, I have had nothing but trouble with my V-Tech ia5823.
Slow to dial, dropping out going calls and now the base light is flashing at a rapid pace and will not charge the handset.
I want to return it to Wal-Mart but have misplaced the recepit.
I will never buy another V-Tech..Uniden is the way to go!
SOURCE: how can I set the phone for speed dial
try to press the number for a while but only the 234567890 the 1 you never cant do it
SOURCE: I have a vtech wireless
If you have a second phone line in the house check to see if that works, if not, proceed with the next step.
If you have a cell phone try calling yourself, and see if the phone
rings or if you get a busy signal, or an operator message that can
confirm if the phone company disconnected your phone service. If you
get a message your phone has been disconnected, call your phone company.
Unplug your phones for at least 15 minutes, all phones in your hose and all lines just from the wall jack and power from the cordless phones.
After 15 minutes plug your phones back in the jack one at a time, pick
it up and see if there is dial tone. If not the phone might be
defective.
Take care.
