Try looking on side of the chimney / flue for a rewritable thermal fuse. Will have two wires coming out of it, reset button between them. Press button to reset. If still inop, use a test light and probe across the wires. Clip onto one and probe the other. If the reset button was pressed, and test probe light is on, then you have a bad thermal fuse.
If the thermal fuse resets, take a hard look at why it may have tripped. Operating off level, operating in high temps, blocked ventilation, leaking cooling unit.
pls check compressor capacitor and compressor termonal connection start the unit check the voltage at the compressor terminal if is ok means copmressor need replcement
