First, I'm not a Compool representative.
* Check your warranty. Call for support; 800-458-2201
Monday-Friday 8:00-5:00 PM (Pacific)
* also 415-964-2201
* Contact; WWW.compool.com
*** The following is for information only.***
* Manual; http://www.poolinspections.com/manuals/controls/compool_cp3400.pdf
* Note pages 23-24 mentions a telephone auto trouble call function.
* Check page 38 for trouble shooting.
* Call support for additional advice.
Aloha, ukeboy57
SOURCE: Spa water drains to pool
Here is a link to the Aqualink website so you can download a trouble shooting guide.
SOURCE: We just moved into our home and there is no manual
Here is a link for the Manual and trouble shooting guide. Aqualink
SOURCE: My pool heater will not start. The power light is off and the pressure sw is lit.
You must turn on the pump and let water circulate through the pool and the heater before you turn on the heater otherwise you will ruin the heater
SOURCE: I have a Compool lx220 control for my pool solar
Check the valve actuator toggle switch. It is 180 degrees out. If the toggle switch is in the up postion flip it down or vise versa.
SOURCE: Purex Triton Minimax 400 pool/spa heater not igniting
This sounds like you have a problem with your pilot. You can check this with a small mirror to see if their is a spark when you turn it on. If you have any soot build up on the pilot that will stop the spark and keep it from lighting also. If you have a short on your pilot wire this could be the problem also. I hope this helps, good luck.
