Dreamsky DS206 Alarm Clock Radio How do you change the station for the wake to radio.
  • Jason Denny
    Jason Denny Jul 09, 2019
    Work around if no instructions. Set radio to desired station in sleep timer mode (for 10 minutes worked for me). When the alarm went off, it was on that station the next day!
  • Jason Denny
5 Related Answers
informatica
Greg Cann
  • 1114 Answers
  • Posted on Aug 30, 2007
SOURCE: Setting a Radio Station for Wake Up
You can download the manual from the link below: http://157.254.235.130/public/RP3721%20EN.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
A
Anonymous
  • Posted on Oct 02, 2007
SOURCE: How do I reset the radio alarm preset on Timex (T307S) Clock Radio
if the radio alarm is still showing the nonexistent 98.5, you would need to reset the radio alarm. Press and hold button 1 (top left hand side) until the display starts blinking. Then press the preset button for 98.1. It should then display 98.1 on your radio alarm. good luck this is the most difficult set of instructions I've seen yet
Anonymous
  • Posted on Apr 22, 2008
SOURCE: Zenith Z212B CD clock radio
Have you done the presets on the memory. Do that then select the station you want to wake up to. Hopefully its fm. Per the instruction manuel . Set or adjust the alarm time if necessary. Press the Alarm on/off button if necessary until one of the alarm indicatior either the note or alarm appears on display when the buzzer alarm is selected. While the alarm time display is flashing press the tuner button to select am, fm, or tv band. The selected indicatior appears in the display ( Note : you can only select the band when you have selected wake to music. While the alarm time display is flashing press one of the preset buttons to select the station you wish to hear when the alarm goes off.
Ralph Faught
  • 70 Answers
  • Posted on Dec 20, 2008
SOURCE: Z213B Clock Radio
d3b32db.jpg 281dcb6.jpg Good luck.
Anonymous
  • Posted on Mar 25, 2009
SOURCE: no fm or am reception on my bose wave alarm clock radio
I had the same problem took off the two screws in the back and one under the cd cover once I took it apart the am rod was loose i put a piece of duct tape to hold it down and it works great, don't drop it anymore
2answers
On TEAK Alarm clock radio USB charging I want to make it wake me up with radio music not buzzer. How do I fix that
Can you comment with the model number? It will be on the information sticker on the radio itself. It will possibly start with 'CRX-'.
Try this - Press and hold the alarm set button until the display flashes like your setting the alarm time. Click the same button again and it should swap between buzzer and radio each time you click it. It will probably show some sort of logo on the display telling you which it is set to.
Where can I find the instructions for the Dreamsky Projection Alarm Clock radio?
https://directbrown.weebly.com/dreamsky-alarm-clock-radio-user-manual-ds201.html#dreamsky-alarm-clock-radio-user-manual-ds201
Sep 29, 2020 • Toys
I have the emerson smartset clock radio. model cks1702. i need the mannuel so i can set it to go off through the week
There are several SmartSet clock Radios by Emerson. Which model do you have?
It's possible that you have alarm 1 and alarm 2 both set for weekends (if a two-alarm version). For the SmartSet radio, CKD5811, that I am used to, you can change the alarm mode between Everyday, Weekdays and Weekends. Press and hold the Alarm 1 (or Alarm 2) button then press the Alarm Mode button to toggle between the modes. Then release both buttons. If you press the Alarm 1 button, you will see the current alarm mode indicated by the indicators by the day that are lit. The Alarm Mode button is between the On/Off button and the Alarm 1 and 2 buttons on the CKD5811. Make sure that you have the Wake to Radio, Wake to Buzzer or Wake to CD slide set for the alarm in question. For Wake to Radio, set your station. For Wake to CD, make sure that the CD in the unit is one that actually plays in the unit (scratches, etc). Also check the volume (although that seems like less of a concern since it does wake you on weekends).
The manual for the CKD5811 is here:
http://www.emersonradio.com/resources/owner_manuals/manual_1312917117.pdf . Additional manuals are here: http://www.emersonradio.com/owner_manuals.php . Scroll down in the drop down menu for the SmartSet manuals (clock radios all start CKD). The manuals are in alphabetical order.
I hope this helps.
1helpful
How do I change the radio station on the radio alarm
Here is the full manual
http://www.timexaudio.com/pdf/T311IB57574_35.pdf
Here are the instructions from the manual.
Setting the Radio Alarm
1. Press and hold the
Radio Alarm Button. The display will flash and the Radio Alarm Indicator will
appear. If you do not begin setting the time within ten seconds of pressing the button, the display will stop
flashing and you will need to press the
Radio Alarm Button again.
2. While the display flashes, press the Reverse and  Forward Buttons to set the wake time. Hold a button
for a few seconds to set the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator.
3. After setting the radio alarm time, you will need to select the station. First, press the  Radio Band Button
to select a radio frequency. Next, select a station using the Memory Set 1-6 Buttons. For more
information on programming radio stations into memory, see the Programming Radio Station Settings section
of this manual. Rotate the  Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting
lets you set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that
the correct date is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual.
While the display is still flashing, press the  Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the  Enter Button. The
Radio Alarm Indicator will appear on the display, showing that the radio alarm has been set.
12helpful
Lost manual for a timex t307s
Setting the Alarm 1 for AM/FM Radio
1. Press and hold the 2 Radio Alarm 1 Button. The display will flash and the Radio Alarm Indicator will appear. If
you do not begin setting the time within ten seconds of pressing the button, the display will stop flashing and you will
need to press the 2 Radio Alarm 1 Button again.
2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the wake time. Hold a button for a few
3. After setting the radio alarm time, while the display is still flashing you will need to select the station. First, press the
L Mode/DST Button to select a radio frequency. Next, select a station using the M Memory Set 1-6 Buttons. For
more information on programming radio stations into memory, see the Programming Radio Station Settings section of
this manual. Rotate the O Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting lets you
set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that the correct date
is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual. While the display is still
flashing, press the 9 Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the 4 Enter Button. The Radio Alarm
Indicator
Setting Alarm 2 for Nature Sounds/Buzzer
1. Press and hold the 7 Nature Sounds/Buzzer Alarm 2 Button until the Alarm 2 settings and Sounds Alarm
Indicator appear on the display.
2. Press the 1 Reverse or 6 Forward Button to set the Alarm 2 time.
3. Use the L Mode/DST Button to select a nature sound or the buzzer to wake to. There is a choice of five sounds:
Sound #1: Ocean Surf
Sound #2: Birds
Sound #3: Brook
Sound #4: Wind Chimes
buz: Buzzer
4. See Note #4 in the Setting Alarm 1 section for instructions on setting the 7-5-2 alarm setting for Alarm 2.
5. After you have programmed the Alarm 2 settings, press the 4 Enter Button or wait ten seconds to return to the clock
display. The Sounds Alarm Indicator will appear on the display, showing that the alarm is set.
3helpful
2answers
Top The Audio Players & Recorders Experts
vince
Paul Carew
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
