Question about Brother Office Equipment & Supplies
How do I Fix Brother Printer Offline Status Error on Windows 10? Printer Setup & Support Call 1-(805) 225-6690 We are 24 Hour Available Call Now For Help
    New Friend:
  • 48 Answers
Make sure the ip on the printer is the same ip that is set on the printer properties on the computer.
If you need more help, consider downloading the 6ya app for your Iphone or Android from the Apple Store or Google
Play Store and giving us a call via the easy to use app. Any of us would be happy to give you a hand further.
Thanks!
Charles
Posted on Aug 03, 2018
6ya staff
SOURCE:
Anonymous
  • 51 Answers
SOURCE: LaserJet 1600 offline status
Is the print server being assigned a IP address in your network?
Posted on Mar 05, 2008
Jigawatts
SOURCE: Printer status offline
I just ran into the same problem. The computers on the network that were running XP were showing the printer as "Ready", but all of the computers running Vista were showing the printer as "Offline".
After trying a number of solutions that I found on other message boards, I accidentally discovered that the problem was an IP address conflict. It seems that the server changed the address on the printer, which didn't bother the XP machines but brought the Vista machines to their knees.
Press and hold the blue button (HP called it the "Go" button) for 5 seconds, which will print a configuration report. In the TCP/IP section you will see the IP address for the printer. Next, open the Printers window, right-click on the P2015 and click Properties. Click the Ports tab. Find the port that is checked and click the "Configure Port..." button. If the "Printer Name or IP Address" field differs from the IP address on the configuration report, change it to the one on the report. It took a few seconds after hitting OK for the computer and prrinter to link up again, but that solved the problem for me.
Posted on Dec 03, 2008
Anonymous
SOURCE: Brother mfc8460n wireless printer going offline.
I had the same problem and call customer service (877-276-8437). Customer service will walk you through the process. You will have to configure you I.P. address along with other steps.
One thing I can tell you is to make sure under the Menu option...Network....WLAN...TCP/IP...BOOT Method....make sure it states STATIC.
Posted on Jan 08, 2009
Anonymous
  • 3 Answers
SOURCE: Can't print because of Error-offline status.
I found out that the IP address on the printer was different from the IP address that was available when the printer was first installed. After spending days trying to fix this, it was resolved in less than two minutes.
Go to the Printer Folder in the control panal and choose to Add a Printer. You will see the option to add the new printer ( wireless). Chose to install, and it will install the printer under the new IP address. It worked instantaneoulsy.
You also need to make sure the IP address is inputted into the printer ( check your guide for how to input the IP address)
What I dont know how to do is to keep the IP address static. Afger, it is not practical to do this each time it changes. If only the last digit changes, it may be as easy as switching to the printer available under the current IP address.
Cheers,
DeniseA
Posted on Mar 14, 2009
Anonymous
SOURCE: printer status offline needs to be online
Do you mean it says "offline" under the printer icon in your PC's printer dialog box?
Right click it , then select "use printer online".
Please let me know
Posted on Apr 04, 2009
Says printer error...wont print
Sir/Madam
If Your Brother Printer Not Print Then Please Go To Official Brother Printer Website To Perform Below Step :
The printer status is Offline or Paused For Windows Brother
If your question was not answered, please check...
Or
Still Having Brother Printer Problem then Follow Us For On :
Jan 19, 2014 | Brother HL 2270DW Laser Printer
Printer offline
Depends on your OS you need find "printer and faxes" or "printer options on the hardware.
  • Open the Start menu and click on the "Devices and Printers" icon. This will open a window with a list of the printers currently set up on your computer.
  • Double-click on the icon of the printer you want to change to online. The status of the printer will be shown as either "Printer: Ready" or "Printer: Offline."
  • Click on "Printer: Offline" and the Printer menu will appear. Click on "Printer" in the menu bar and uncheck "Use Printer Offline." This action will change the printer from offline to online.
May 12, 2013 | Office Equipment & Supplies
"The printer is offline. Check that
Issues or errors within the operating system might also cause printer offline issue. Users having offline printer issue are advised to clean the registry of the system, check integrity of the system files and also remove any malware infections using an updated antivirus program. Users must also stop the printer service active on the system and restart it as the issue might be because of errors. Removing the errors from the system would get the printer working without issues.
Jan 18, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Why does my Brother printer goes into Sleep mode and I can't print??
I have copied in the illustrated instructions for resolving printer status is Offline or Paused. (For Windows®) but if distorted please view here.
The printer status is Offline or Paused. (For Windows®)
Description:
To solve the problem, please see the following:
  • If the printer status is Offline:
    Check that the printer is online using the following steps:
    VERIFY THE BROTHER MACHINE IS POWERD ON AND THERE ARE NO ERRORS
    1. If the LCD screen is blank, then the Brother machine is not powerd on the machine to see if it wakes from sleep mode. If it does not, then verify that it is plugged into a working outlet and any power switches are turned to the ON position.
    2. Check the LCD screen for any error messages. An example would be "Paper Jam" or Ink/Toner Empty". If the LCD screen shows an error troubleshoot to clear the isssue indicated.
    CHECK THE PRINTER STATUS
    NOTE : These steps or screens may differ depending on the operating system.
    1. For Windows® XP Users:
      Click Start => Printers and Faxes
      For Windows Vista® Users:
      Click Start => Control Panel => Hardware and Sound => Printers
      For Windows® 7 Users:
      Click Start => Devices and Printers
    2. For Windows® XP and Windows Vista® Users:
      Right click on the icon for your Brother machine and choose Use Printer Online.
      Double click on the icon for your Brother machine => See what's printing => Printer => Use Printer Offline (Take the checkmark off.)
Note If the problem still continues, do one of the following:
  • If you find the Related FAQ's at the end of the page, click it and check another solution.
  • If you don't find the Related FAQ's, please contact Brother Customer Service from "Contact Us".
  • If the printer status is Paused:
    Right click on the icon for your Brother machine and choose Resume Printing. (If the menu reads Pause Printing, there is no problem in the printer status.)
    Double click on the icon for your Brother machine => See what's printing => Printer => Pause Printing (Take the checkmark off.)
    If this does not solve the problem,
    Double click on the icon for your Brother machine and choose Printer => Cancel All Documents.
    Double click on the icon for your Brother machine => See what's printing => Printer => Cancel All Documents
If you are using Windows Vista or Windows 7 please view here.
Trust this is helpful.
Dec 17, 2010 | Brother MFC 7840W Printer
I have a Brother MFC 6490CW printer. I have been using it wireless for the past 6 months. When i had a problem with the auto tray select, i reloaded the printer and it constantly goes back to OFFLINE. ...
If you are setting up a wireless printer in Windows 7 then there may be different issues that can appear while installation. If the status of your printer is offline then you have to reinstall the drivers of printer on Windows 7-based system.
Nov 23, 2010 | Brother Office Equipment & Supplies
How to solve 'error S01'?
1. Verify USB cable is connected directly from USB port of printer and the USB port on back of computer. If not, connect directly to both the printer and computer and try to print. If the printer does not print, go to step 3.
2. VERIFY THAT THE BROTHER PRINTER IS SET AS DEFAULT
This is especially important if you use the print icon to print from within applications. If the Brother printer is set as the default printer, it will have a check mark. If it is not set as default:
To set your Brother machine as the default printer, RIGHT CLICK on the Brother printer and select SET AS DEFAULT (PRINTER).
3. VERIFY THAT THE PRINTER STATUS IS READY AND THE PRINT QUEUE IS EMPTY
A. Click on START, RUN
B. Type: CONTROL PRINTERS and click OK.
C. Locate the Brother printer in the list and hover your mouse over the Brother printer icon. Below is an example of what you may see:
Status: Ready (Could also state: USE PRINTER OFFLINE or PAUSED)
Documents: 0 (Could be any number)
D. If there are any documents waiting in the queue, right-click on the Brother printer and select CANCEL ALL DOCUMENTS, depending on your operating system. This should clear the queue.
E. If the status states: USE PRINTER OFFLINE, right-click on the Brother printer and select USE PRINTER ONLINE depending on your operating system. This should set the printer driver ONLINE.
F. If the status states: PAUSED, right-click on the Brother printer and uncheck PAUSE PRINTING. This should allow the printer to resume printing.
G. If the status is ready and no documents are in the queue, attempt to print the Windows test page. If not successful, verify the selected port. If USB is the selected port follow step 4. If USB is not selected,change the port to USB, then attempt to print the Windows test page. If not successful proceed to step 4.
4. Turn the printer OFF.
5. Close any open programs.
6. Click Start, Run, type: control printers
7. Right click Printer, left click Cancel All Documents (if available). Confirm if necessary (click OK).
8. Right click Printer, left click Delete. Confirm if necessary (click OK).
9. Left click File menu, left click Server Properties, left click Driver tab, left click print model name, left click Remove button, click Confirm.
10. Close the Print Server Properties window to return Printers and Faxes window.
11. Check that the USB cable is properly connected at both ends.
12. Turn the printer ON.
13. Wait until printer has ready light or green status, watch the Printers and Faxes window to see if printer is automatically reinstalled.
14.a. If printer was automatically reinstalled, right click Printer icon, left click Properties, left click Print Test Page button. If the printer is not automatically reinstalled, call Brother Customer Service at 1-877-Brother (1-877-276-8437).
b. If printer was not automatically reinstalled, try a new USB cable. Ifthe printer still is unable to print, call Brother Customer Service at1-877-Brother (1-877-276-8437).
Nov 02, 2010 | Brother HL-5270DN Laser Printer
My printer says it is offline
Oct 26, 2010 | Brother MFC255CW All-in-One InkJet Printer
My Brother HL-5250DN is shown as offline. I am using Windows 7 and a 64-bit machine.
Open the "Printers" window.
Click with the SECOND (usually the RIGHT) mouse-button on the printer.
Click to "go online" or "use online" or click to disable the "offline" status.
Dec 29, 2009 | Brother HL 5250DN Laser Printer
223 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
