SOURCE: Yamaha outboard engine
Procedure for carb. adjustment for 1992 Yamaha 30 h.p. 2 cycle outboard motor
SOURCE: speedo for a 80hp yamaha outboard
The sender is a plastic flip up fitting located at the bottom of the transom. They have two positions. Down and in the steam below the bottom of the water for reading the speed. Up to protect when trailering. Check to see if it is up. I never heard of a unit that is attached to the engine itself.
SOURCE: ignition point gap and spark plug gap inboard outboard omc
.019 for the points and .035 for the plugs
