SOURCE: I need a user manual
I need access to the spark plug module for replacement. The plastic stove top seems sealed to the metal housing. How do I gain access? Creda GH 102 series cooktop. Spark Module Replacement.
SOURCE: I cracked my Schott Ceran Cooktop glass
I located a company that supplies a new top but only to find that the tops are 400.00 anyway. I ended up purchasing a new stove to solve the problem.
SOURCE: Hello I have a Miele Deluxe H818 oven
Hallo I have a Miele Deluxe H818 oven too.
I do not use my cooktop because I buy new with gas-metan.The original cooktop is only electrical.
Ivo
SOURCE: My schott ceran class top stove keeps saying F1 on
Here below we have aprocedure to try to see if you can save the ERC.
F1 touch pad / ERC test
This simple test will help determine
whether the ERC (Electronic Range Control or Clock) or the touch pad is
defective when F1 error code is present.
Note: Some models
incorporate the touch pad in to the ERC as a single assembly, in which case this
test is not necessary. Simply replace the ERC (Clock).
Warning: If
you feel in any way uncomfortable performing this test or making this repair,
please contact a qualified appliance repair technician.
1. Disconnect
power to the range (unplug the range power cord or turn the power off to the
range at the circuit breaker). It is very important that the power to the range
has been disconnected, so please double check before continuing.
2. Gain
access inside the control panel.
3. Disconnect the touch pad (also called
keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no
lose wires, or anything else that may cause a short when power is turned back
on. Assemble the control panel back the way it was.
5. Turn the power back
on.
6. Wait for at least one hour to see if the F1 code comes back (usually
accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it
does not, replace the touch pad.
SOURCE: My miele induction schott ceran
If you have an illuminated red key symbol on the cooktop, press down where the illuminated red key is, for about 5 seconds. This method works on many Schott Ceran / Miele cooktops including the KM443 listed above.
If this doesn't work, please let me know the correct model number.
Hope this helps.
Regards,
BElectric
