Question about AMP Car Audio & Video
How many watts per channel is a sharp sx 9800 power amp
  • AMP Master
  • 1,176 Answers
Around 350 watts.
Posted on May 07, 2019
6ya staff
SOURCE:
Anonymous
  • 5 Answers
SOURCE: 600 watt 2 channel power acoustik sterling amp
On your amp, there should be a switch (on the side probably) that has "LP", "HP", and "FULL" or "OFF". This is a switch for the low pass/high pass filter. Switch it to "LP" as this will allow only low frequencies to go to your subs, what you want. If you don't have that switch, go to an audio store or online audio supplier and get either a low pass filter, band pass filter, or a cross-over, and follow the wiring diagram that comes with it to filter out the high frequencies before they get to your subs.
Posted on Oct 09, 2007
robotek
Graeme Ross
  • 1512 Answers
SOURCE: Power Amplifiers
any luck??
Posted on Apr 21, 2008
Anonymous
  • 631 Answers
SOURCE: Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Posted on Nov 02, 2008
Anonymous
  • 5 Answers
SOURCE: Pioneer SX-950
use a cable tester for the wires that are connecting to the unit and you'll find the faulty wire that is bad.....good luck
Posted on Dec 20, 2008
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: i have a crown ce 2000 watt amp. channel 2 keeps turning off
Do you get any Fault indications?
Have you swapped the speakers around to eliminate them as external causes?
When the channel dies is the unit very hot and is the fan turning very fast (it should be if hot)? The fan could be defective, slow or airflow may be restricted.
Turn the amp off and examine the fan guard on the rear to make sure it is clear of dust and debris. Vacuum it out if necessary. With a small thin non-metalic object reach in and test the fan for free movement by trying to rotate it. It should coast.
Posted on Apr 28, 2009
Hi,I have two 250w speakers at 8ohms ,could someone tell me if I need to get a amp with higher watts than the speakers?k
Speakers are rated either at RMS (root mean square) average power or Peak Power. An RMS of about 125 watt is equivalent to 250 watt peak. To match the radio and speakers they both need to be consistent. Also do not be confused with total radio power out vs per channel.
So if the speakers are 250 watt peak power then a radio with 125 watt per channel or 250 watt peak per channel would be a good match.
If the speakers are RMS 250 watt then the radio would be 250 RMS/channel and usually with a four channel radio a total of 1000W RMS
With that much power the neighbors should hear you coming!
Dec 02, 2015 | Car Audio & Video
What is the actual watts per channel @ 8-ohms and 4-ohms on the Behringer PMP3000?
Those specs would be right - I have this same board but the amp was fried by a previous owner. I pulled the amp board out and tossed it and use the mixer now to drive an external amp. Great board. This amp is rated at 1200W "peak", bridged into an 8ohm load. That would equate to about 900W RMS bridged into 8ohm or 450 per side into 4ohm loads per side. You can't daisy chain all 4 speakers....impedance would be too low. You can run two of your 8ohm speakers per side - that results in a 4ohm load per side for the amp. That would give you amp delivery of 450W per side. Your speakers are rated to handle more than that so you're fine. For the record.....you could run one speaker per side no problem....just lower power output.
Aug 16, 2012 | Behringer Pmp3000 16 Channel Audio Mixer
I got my hands of a Sharp Power Amp SX-9800. It has a power cord and a set of RCA jacks (1 red, 1 white) plus two bare wires (no jacks or connectors). It has several speaker outlets. How do I hook this...
Which is it 9860 or 9800? (No web search hits for the 9800).
JVD Tuner?
The RCA jacks on any amp so-equipped are for any external Line Level source like a tuner.
In any 'connection' question there are at least two participants and specific answers require specific details about all joined equipment.
Type carefully if you want good answers.
Sep 23, 2011 | Sharp SX9860 2-Channel Amplifier
Hi, i have been suggested first a Samson servo 600, then a sx1200 is there a difference between the 2? is one better than the other?
the servo series is geared more towards studio applications and/or installs, while the sx series are geared for live pa applications. the servo 600 is 300 watts per channel @ 4 ohm, and the sx1200 is 450 watts per channel at 4 ohms. the sx amp can also be bridged over to mono mode, where it puts out, i think, 1100 watts mono.
the only variable i havent been able to cover is sound quality, and im not seeing those listings in the specs on the samson website
Jan 12, 2011 | Samson SX1200 Amplifier
Wattage
I have the following specs for you
Basically 150watts per channel using two channels , or 75watts using all four
Here goes:
  • 4 Channel Mosfet Amplifier
  • Advanced Overload and Thermal Protection
  • Metal Film Capacitors/Resistors In Signal Path
  • Frequency Response +/-1dB, 20Hz to 20 kHZ
  • Signal to Noise Ratio (A-weighted) >100dB
  • Max Continuous Bridged Power @ 1% THD 150 watts x 2 into 4 ohms @ 14.4 Vdc
  • Max Continuous Power per Channel @ 1% THD 75 watts x 4 into 2 ohms @ 14.4 Vdc
  • Nominal Continuous Power per Channel @ 1 % THD 35 Watts x 4 into 4 ohms @ 14.4 Vdc
  • IASCA/USAC Power Rating 12 Watts x 4 into 4 ohms @ 12.5 Vdc
  • Minimum Load when Bridged 2 Ohms
  • Minimum Load per Channel 1 Ohm
  • Input Signal Voltage Range 0.1 volts to 2 volts
  • Crossover Type Resisitor Network, Linkwitz Riley,
  • Highpass/Lowpass
  • Crossover Slope 24 dB per octave
  • Crossover Frequency Range 20-550Hz
  • Factory Crossover Setting 85 Hz
  • Auxilary Output Channels 2
  • Auxilary Output Frequency Range Highpass or Lowpass, Opposite of Speaker Output
  • Bass Boost 0- to +18dB @ 45 hZ
  • Power Supply Voltage 10Vdc to 15.5Vdc
  • Recommended Fuse 40 amp
Dimensions 12.25L x 9.25W x 2.10H
May 23, 2010 | Car Audio & Video
2003 Cadillac DTS w/Bose, has rear sub & adding Pyle dual 10 sub
two channel will do with the same power power rating of your speakers ex. your speaker is 500 watts per piece so you need to buy a 500 watts per channel amplifier
May 16, 2010 | Pyle PLHB10 Car Subwoofer
What is the output of the 451s rms power
Dynamic Power Rating (measured at 14.4V):
  • Bridged Into A 4-Ohm Load: 450 watts x 1
  • Per Channel Into A 2-Ohm Load: 225 watts x 2
  • Per Channel Into A 4-Ohm Load: 115 watts x 2
Apr 14, 2010 | Rockford Fosgate Punch 401S Car Audio...
I have a boat with Clarion CM1635 speakers, how do I size the amp for my speakers
Hello cgregerson,
If you are running just the front channels to 2 CM1635's, you will need a 2-channel marine certified amp with approximately 50 watts RMS output per channel.
The MB Quart NAU-260 here would be a good inexpensive choice.
For a little more power and quality, I'd recommend the JL Audio M2150.
To run both front and rear channels, you need a 4-channel amp with 50 watts RMS per channel.
The Kicker MX350.4 marine certified amp would be a good choice.
Hope this helps.
Oct 14, 2009 | Cyclone Car Audio & Video
I found this amp and I can't seem to figure out what the wattage is?
You are probably aware on how to use these output figures, but I'll write a quick explanation on the specifications for future readers anyways :)
The concpet CC-452 amplifier has the following power output specifications:
Calculated at 14.5 volts DC;
At 4 ohms per channel - 45 watts x 2 (RMS)
At 2 ohms per channel - 70 watts x 2 (RMS)
At 4 ohms bridged - 150 watts x 1 (RMS)
This means that your amplifier would provide 45 watts of power each for your front speakers, which are normally a 4 ohm load per side (45 watts for left, 45 watts for right), that's unless they are one of those exotic higher end brands (eg: Boston Z6s which are 3 ohms). Rarely, you will find speakers that are rated at 2 ohms per side, but in this instance the amplifier will provide 70 watts of power into each speaker. On your speaker specifications, you will find a value termed "nominal impedance" which will give you the ohm rating of the speakers being used..
On the other hand, if you "bridge" both channels into a single channel (using a diagram often marked on the speaker terminals of the amp), you could then provide 150 watts into a subwoofer (providing it was a 4 ohm woofer).
It's not recommended to use this amp bridged under 4 ohms..
Some subwoofers may be lower than 4 ohms, and you will not be able to use this amplifier for these types of speakers without risking amplifier failure. Also, some subwoofers may have 2 seperate voice coils, and you will have to use both channels of the amplifier seperately (not bridged) in order to correctly connect this type of speaker for use.
Oct 28, 2008 | Concept CC-452 Car Audio Amplifier
Car Audio & Video Logo
266 people viewed this question
Top AMP Car Audio & Video Experts
Billy McCain
Billy McCain
Level 1 Expert
ray gallant
Are you an AMP Car Audio and Video Expert? Answer questions, earn points and help others
