The Square D pressure switch is set from the factory to turn off at about 130 psi. Look on the inside of the switch cover for details. If the contacts are welded together or other part failed in the switch the compressor will continue to run till safety valve opens. Replace the switch or just keep using the pilot valve. Good luck on repair.
