It will run for about 40-50mins when I give it a spin from stalled. It then stalls again, and I get one of the following error codes: F5 (not FS), F51 or F55. Any ideas on the error codes or problem with the fan or capacitor?
seems like an air-locked gas tank (remove gas cap as a test) or dirty fuel filter....
SOURCE: Sputters and Stalls...
sounds to me like the coil is failing the heat once it is warmed up makes it misfire so once it cools again it will start but stop again also check the spark plug wires there may be a bad one or even the plugs it isn't the heads or head gasket or cooling system because you would see white smoke and have water in the oil and vise versa this is a firing issue
SOURCE: mazda keep stalling
Have you checked air and fuel filters? If dirty or never changed (fuel) - replace them.
SOURCE: when braking for stop 1997 venture stalls sometimes
poss. incorrect computer settings, when responding to throttle don.
Video nahi aata
