I can not get my computer to reconize this player. On the icon bar it shows up but when you go to Windows media player 10 to try & sycornize music to it it comes up with no player attached. what is the matter with this player? How do I fix it?
ilo mp-556 computer wont reconize device at all not even showing up in my computer. keeps telling me to put it in a usb port and it is windows media cant sync with it either please help.ilo mp-556 computer wont reconize device at all not even showing up in my computer. keeps telling me to put it in a usb port and it is windows media cant sync with it either please help.
my computor shows the player being connected, but digging futher shows no device hooked upmy computor shows the player being connected, but digging futher shows no device hooked up
I too can't get it to be recognised. My RCA Opal works fine in the same port, so it's not a bad one.I too can't get it to be recognised. My RCA Opal works fine in the same port, so it's not a bad one.
My Windows Media Player 10 says no device has been detected.But there is no device,when i click on My Computer.The same mp3 player of my sister's,works but mine don't.I used the same UBS cord,but i did not work.But the mp3 player worked on the office computer!My Windows Media Player 10 says no device has been detected.But there is no device,when i click on My Computer.The same mp3 player of my sister's,works but mine don't.I used the same UBS cord,but i did not work.But the mp3 player worked on the office computer!
I have the same problem, I cannot get my computer to recognize this MP3, it is impossible,I have the same problem, I cannot get my computer to recognize this MP3, it is impossible,
Windows Media Player 10 and 11 no longer recognizes MP-556 MP3 Player. It doesn't even show up as a supported portable devise,so I cannot transfer any more files to this Ilo wma Player.Windows Media Player 10 and 11 no longer recognizes MP-556 MP3 Player. It doesn't even show up as a supported portable devise,so I cannot transfer any more files to this Ilo wma Player.
My ilo mp 556 wont register in my computer when I plug in the USB to my computer I need some help.My ilo mp 556 wont register in my computer when I plug in the USB to my computer I need some help.
I can't get this player to work anymore! All I did was change my low Duracell battery into energizer and all of a sudden some of my songs were gone and their names were switched around! I thought this was annoying so I decided to hook it up to my laptop to check what the hell happened. Well it worked at first but then when I clicked on the internal storage it just shut itself off and restarted. After that I haven't been able to hook it up and all my music (62) has been wiped out! I need a way to fix this now!I can't get this player to work anymore! All I did was change my low Duracell battery into energizer and all of a sudden some of my songs were gone and their names were switched around! I thought this was annoying so I decided to hook it up to my laptop to check what the hell happened. Well it worked at first but then when I clicked on the internal storage it just shut itself off and restarted. After that I haven't been able to hook it up and all my music (62) has been wiped out! I need a way to fix this now!
Works fine by itself but won't show up in comp anymore. It used to do it just fine... now I am looking for a way to get it recognized again. Can anyone help? http://youtube.com/SimbiAni1Works fine by itself but won't show up in comp anymore. It used to do it just fine... now I am looking for a way to get it recognized again. Can anyone help? http://youtube.com/SimbiAni1
AnonymousMay 27, 2008
It comes up as an unrecognized device, and nothing has changed to make this happen. help!It comes up as an unrecognized device, and nothing has changed to make this happen. help!
AnonymousMay 30, 2008
my player does not show up on devices bar
AnonymousOct 15, 2008
Same here. And it will not stay on when turned on. Gets 1 dot after "Flash loading" then shuts down.Same here. And it will not stay on when turned on. Gets 1 dot after "Flash loading" then shuts down.
what you might want to do is to rip the songs from the cd as an mp3 songs/go to your windows media player tools setting and change the rip file to MP3 instead of WMA...
YOU HAVE TO SYNC THROUGH MEDIA PLAYER - IT DOES NOT RECONGIZE SONGS IF YOU JUST COPY THEM ONTO THE SD CARD.
FOR VISTA -This player only seems to be able to transfer MP3 format with Vista, using windows media player syne. Unless someone found otherwise.
FOR XP PRO When using XP Pro and Windows Media Player you can transfer WMA but you have to go into the PROPERTIES of the drive (mine was mp-556/G: drive) and DESELECT the option to transfer FOLDER HEIRECY. The MP3 player is not able to reconginize the folder structure it usually creates by default.
I just got an ilo mp3 player and when I try to sync songs from Windows
Media Player 11 to it, it only puts about 1/2 of the songs on it. It
says it has plenty of memory, so what's the problem?
When using XP Pro and Windows Media Player you can transfer WMA but you have to go into the PROPERTIES of the drive (mine was mp-556/G: drive) and DESELECT the option to transfer folder hierecy. The MP3 player is not able to reconginize the folder structure it usually creates.
You cannot just move WMA songs onto the card and play in the MP3 player. MP3 format may work this way, but for sure the player only seems to be able to recongize WMA files when syncd through Windows Media with the USB cord attached. Be sure the DESELECT 'copy folder hierecy' under the sync options/properties of the MP3 player drive or SD card drive.
This player only seems to be able to transfer MP3 format with Vista, using windows media player sync. I can syne MP3s formats, but not WMAs at all. Unless someone found otherwise
http://www.lenoxx.com/2005/mp3player/mp556.htm
if you have a ilo model mp-556 (on the back cover) this page has links to the firmware ... i follow the instruction and got mine working.
read the instructions carefully. using media player is not a drop and drag situation u have to jump through some hoops to make it work that way. it in the instructions. http://www.lenoxx.com/2005/mp3player/mp556.htm
u might need to use the reformat as well as the upgrade firmware to make your list read the same. reformating will set your storage area back to factory specs. i e delete all your songs on your player
I tried to download this device and my computer says it's not there ...
my mp3 player writes FLASH ERROR everytime i try to play it
