Question about GPX Audio Players & Recorders
How do I play CD player on gpx model # crcd6306dt i don't know what buttons to push
6ya staff
SOURCE:
Anonymous
SOURCE: Need owner's manual for GPX under-cabinet radio CD player
http://www.gpx.com/
then go to support
Posted on Dec 26, 2008
SOURCE: Using PC308B GPX portable CD player
Im sorry but the GPX PC308B does not support MP3 format so you won't be able to listen to the audio books.
Thank you for stopping by Fixya hope this helped, if so feel free to leave positive feedback.
Posted on Jan 08, 2009
Anonymous
SOURCE: Loading music on gpx mp3 player
go to poilit or some your commfortable with. down load to pc the stuff u want, then move this to your windows media center plug mp3 to your pc. then open media center it will ask download to device or cd clik device and it will do the rwest
Posted on Apr 28, 2009
Anonymous
SOURCE: gpx dvd player model D1816
We have the problem fixed. My nephew did it when he stopped by on his way home to Georgia. Sorry I can't tell you what he did. Thanks anyway.
Not interested in the plan.
Posted on Jun 26, 2009
MNfisherman
Nate Stansfield
  • 11896 Answers
SOURCE: CD player stopped working
Most likely faulty lens eye or circuit. YOu can try to clean it with rubbing alcohol and cotton swab, otherwise it will have to be swapped out
Posted on Aug 04, 2009
Set time on clock radio CS238-5G
This is the way I worked it out, as soon as you've plugged in the unit, push the MEM button for a couple of seconds then push the PLAY/PAUSE button and hour will start to flash then use the arrow buttons to change hour, then push PLAY to change minutes. Once you've finished minutes push PLAY again. Not sure about setting alarms though and if you get stuck, unplug it and start again.
Mar 26, 2014 | GPX CRCD6306DT Clock Radio
Can't play the cd
After putting in the CD, move the switch on the back to the CD/Line In position. (The other switch positions are Off, AM, FM.) The switch is next to the Line In (3.5 mm) jack. Then press Play/Pause on the front of the boombox. This is the single button on the left side (The adjacent pair of buttons are the search (reverse/forward tracks). On the other side of the LCD display are the Stop, Repeat and Program buttons.
GPX has the manual for the GPX BC232 on the product page: http://www.gpx.com/store/p/822-BC232R.aspx . Click on the tab for Downloads to get the manual link. The direct link is http://www.gpx.com/owners_manuals/BC232-578-01-IB.pdf . You will need Adobe Reader or a similar program to access the manual.
I hope this helps.
Jan 08, 2013 | GPX BC232R Radio CD Player Boombox
GPX plays music cd's only not dvd's
You need to replace the motor disc spindle because with time lose some velocity and thats why don't play dvds
Sep 30, 2012 | GPX D200B Player
A put in a cd and after about 40 seconds it stops playing a gives me an error signal.
Hello and good morning,
The Error it is saying, is player is dirty.
In the past what I have done and works 99 percent of the time, is I go down to like radio shack or best buy or almost any electronic supply, even stereo install stores will normally have a CD cleaning kit that comes with a fluid that you wipe on the blank CD with the applicator or towel it has in the package. What you will be doing is putting this blank CD that is designed ( with the cleaning solution) to go through your player and clean all the controls and contacts and components. You might have to run it through a few times, then when you think you are done and its is now clean, put a brand new CD or a CD that you know for sure it works, and try and play it again. 99% of the time, this will solve the problem. I hope this helps for you. Rock On!! Mike from fixya.
Aug 04, 2011 | GPX CRCD6306DT Clock Radio
GPX clock radio clock question
I emailed the company and they sent a pdf of the manual back the same day.
partsinfo@dpi-global.com
Jun 06, 2008 | GPX CRCD6306DT Clock Radio
Music wont play or show just keep saying mtp
Uninstall MTP device in device manager and press the M button on the side of this player
Apr 01, 2008 | GPX MW3837 MP3 Player
61 people viewed this question
Top GPX Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Ekse
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
