Battery says it is charged 100%, but tablet doesn't stay on when you unplug the power. Tried rebooting it but didn't make any difference.
SOURCE: battery charging problem.
link to the manual
Read page 9 make
sure you have the
right battery and
that everything is
hooke up right
SOURCE: Shows Li-On battery charged when plugged into AC, shuts down when unplugged
Here is a palm article on the battery not holding charge-
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/
?St=42,E=0000000000826384196,K=1280,Sxi=19,Case=Obj(30029)
My battery loses its charge very quickly
Like all Lithium Ion batteries, the battery in your device will eventually wear out. If you charge your device fully but it loses power after a few hours (or sooner), it may be time to replace the internal battery.
Sounds like you already did this. Do you have someone you know who has the same battery you could try? Or try your battery in their device?
Also this site looks good -
http://www.ipaqrepair.co.uk/ipaq_battery.php
Step #11
You can connect it via USB and let it charge that way a little while, then try charging it normally. It's called trickle charging-
Trickle charging
Some Palm
devices have the ability to "trickle charge" from a USB port on a PC or
Mac. This means that it receives a very small amount of charging from
the USB port, even if it is not connected to its AC charger. If your
device is capable of this function, the charging time will be
significantly longer for a trickle charge (depending on the power
rating of the PC USB port). However, the device may not charge at all
on an unpowered USB hub (or for example off off a keyboard).
SOURCE: OVERHEATING OF THE PLUG-IN AND THE CORD IN GENERAL
Poor contact at the receptacle will cause the plug to heat. Look at the plug prongs for any sign of discoloration or arcing. You may need to replace the receptacle and/or plug.
SOURCE: Compaq C700 laptop keeps powering off , wont power
Try booting into BIOS. If it stays on than you need to reinstall your operating system.
SOURCE: My laptop won't turn on,
Good day. You can try to do these steps which is usually a normal solution to this kind of issue:
1. Take out the battery of your laptop
2. Remove main supply, or power cord
3. Hold power button down for 30 secs,
4. Put only power supply in or power cord
Note: do not put battery in yet
5. Turn laptop on
6. Put the battery in.
If this will not work you might consider contacting toshiba tech support for laptop for other resolution. Hope this information will be helpful in resolving your issue. Thanks for using fixya and have a great day.
When you plug in the power cord is there any lights
whatsoever on the laptop, where the plug goes in or on the AC Adapter of the
power cord?
When you press the power button do you hear fans running, hard drive spinning,
lights on the computer, hear any beeps or lights constantly blinking, hear the
DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a
second or two? If so the laptop is trying to boot or may have booted, but
the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the
laptop and why it is not booting. Most times it's a motherboard issue
when you hear beeps or blinking lights continuous. Most times the problem
is with the memory or Video Card. Count the Blinking Lights or Beeps and take
note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever
when you press the power button. And if that's true maybe you was
operating off the battery the last time you had it on and since the power cord
is bad, it was not charging the battery so the battery is drained and the power
cord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove the
Battery, then Press and Hold the power button for 30
seconds. After 30 seconds plug the power cord back in (leave the battery
out) and hit the power button to see if it boots. If it does, you can put
the battery back in and let it charge.
Maybe your DC Power Jack which is where the power cord plugs
into the computer is bad. Take an ink pen and push the tip inside the
jack and see if the little pin wiggles, if so the jack is bad. You'll have to
take the laptop apart to fix it. Most times it is soldered onto the
motherboard, so you will have to desolder the old and solder a new one.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Remove the Battery, Remove
the cover that houses the memory on the bottom of the laptop then remove
one of the
memory chips. Set the chip aside then try rebooting the computer.
If it boots, then you know the memory chip you set aside is bad so mark
an x on
it with an ink pen. If it fails to boot then move the chip to the next
memory slot and try rebooting. If it fails take the chip out and set it
aside, then put the other chip in and try booting it in both slots. If
it
boots, just to verify that the chip set aside is bad, mark an x on it
and put
it into the open memory chip slot and try booting.
