Go to sears site and use make and model number for manual search
Https://www.shopyourway.com/manuals/search
https://www.shopyourway.com/questions/1113902
Possible different model number, and discussion of similar models since neither manual appears to be online. Craftsman 73756 is similar but not exactly the same, and no manual found online.
Craftsman Clamp meter 034-90273 - no manual found online at Sears or elsewhere in searches.
Possible similar model with a free manual:
https://www.manualslib.com/manual/940105/Craftsman-82011.html
Suggest calling Sears as online search doesn't list it.
Craftsman 82011 Owner Manual
SOURCE: How do you check voltage utilizing the Craftsman
If you don't have to drive, set the multimeter to 20 V DC, and measure on the battery poles. If you'd like to drive during measurement, you could measure on the cigar lighter socket.
SOURCE: need owners manual for a
type this into your web browser owners manual for a Jensen JTM97, digital multimeter and you should be able to get what you need.
SOURCE: i have 800va microtek inverter non sine wave.i want to know what is the output voltage available
The voltage should be the same for both. Maybe one or the other isn't calibrated correctly. Have a friend with another multimeter check the output, and then take the voltage that is the same from his and yours.
