SOURCE: GE JVM1650BB005
You can search under Repair Parts and enter your full model number JVM1650BB005 and get an exploded view diagram here: http://www.geappliances.com/shop/prts/ That diagram can be a great help. Also, I've attached below a door panel diagram from a Sharp model. Your GE disassembly may work the same way. If you haven't already taken the door off the microwave, I would recommend you don't unless you leave the hinge assembly attached to the door and remove the door from the hinges. It's critical to be sure you get (or keep) the door and hinged aligned exactly as they were to prevent leakage.
SOURCE: kenmore microwave oven handle came off
You will need a new handle, and you can probably find an exploded view by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We do not recommend removing the door unless it's absolutely necessary.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: GE Eterna Microwave
Hopefully you didn't disturb the hinges to remove the door, since that will require alignment and testing to be sure it is not leaking.
Normally
and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
SOURCE: outside glass dooor on Whirlpool oven fell off, what do i do?
Normally
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
