If you wish to get some details; visit the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. See the site by a desktop. Mobile view has no search box. If you are viewing it by your mobile, see it in webview.]/
SOURCE: Replaced lamp and now can't get a picture
Hi Sally Jo, Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001. Hope this helps!
SOURCE: Mitsubishi Projection TV WD-62525
I RECENTLY HAD A LAMP ISSUE THAT MAY ASSIST. I HAVE A MITSUBISHI WD-52525 52" DLP. I HAVE OWNED THE UNIT JUST OVE THREE YEARS. THE UNIT INDICATED THAT THE LAMP NEEDED TO BE REPLACED WHEN THE UNIT WAS TURNED ON. I ORDERED A LAMP AND BEFORE IT CAME IN THE UNIT QUIT WORKING. I REPLACED THE LAMP AND WHEN I POWERED UP THE UNIT I GOT A STEADY YELLOW INDICATION AND THEN A SOLID RED. MITSUBISHI TECH ADVICE STATED THAT I MAY HAVE BEEN SHIPPED A BAD REPLACEMENT LAMP. I SENT THE LAMP BACK AND ANOTHER WAS SENT TO ME. THAT LAMP ALSO GAVE THE SAME RESULTS. I CALLED CHUCKS ELECTRONIC REPAIR AND A VERY KNOWLEDGABLE TECHNICIAN RESPONDED TO MY HOME. IT WAS DISCOVERED THAT THE POWER SUPPLY BOARD WAS BAD AND THAT THE LAMP NEVER NEEDED TO BE REPLACED. I SPOKE WITH REPRESENTATIVES AT MITSUBISHI SEVERAL TIMES AND THIS WAS NEVER EXPLAINED TO BE A POSSIBITLY. THE TECHS AT MITUSBISHI BASICALLY JUST READ FROM THE OWNER MANUEL AND HAD NO IDEA WHAT THEY WERE DOING.
SOURCE: Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
SOURCE: Mitsubishi WD-73732 TV
It could be a bad lamp but I've run into many of these TVs with bad color wheel assemblies. Also, if you are getting a dialog box coming up with these words," airflow blocked, TV will shutdown ..." that's a defective thermal fuse.
This is a job for a mitsubishi authorized service center. A tech can disassemble the light engine and confirm that the wheel is the problem. If you're still in warranty, great. If you're only recently out of warranty, call mitsubishi for assistance. Remember that persistance pays off when dealing with large corporations. You very seldom get what you're looking for on the first call or from the first person you speak to.
michtech
SOURCE: Replaced lamp Mitsubishi WD-52531 worked for one day
Ballast Board may be Bad it is what turn Lamp on Call Encompass for parts 1-800-638-3328 or look for one on E-Bay they have good deals on Parts.Also CK Fan to Lamp it maybe defective .Call Mats for Fan 1-800-628-1118 they have lamps also.
