If you want to reset all the settings on Huawei MA5608T to the factory settings, you can erase flash data like below:
MA5608T(diagnose)%%erase
{ flash<K> }:flash
{ data<K>'language<K> }:data
If you just want to reset only the user and password, you can undo terminal user name.
SOURCE: Need Username and password to setup
got to http://purelypc.blogspot.com/2008/04/forgotten-router-password.html
for default login and password.......
http://purelypc.blogspot.com/2008/04/default-logins-and-passwords-for.html
it might help u.
SOURCE: Reset DWL 2700AP to factory defaults
Hi dear try to flow this tips it will help you
Administrator Settings
Administrator settings allow you to customize User Name and Passwords as an Administrator of DWL-2700AP. The default value of the Username is "admin" with no password entered.
Password
Enter a password in the Access Point Password field. Type the password again in the next field to confirm it. The Password is case-sensitive ("A" is a different character than "a",) and must be between 0 and 12 characters in length
System Settings
You may reset the DWL-2700AP back to factory settings by clicking on Restore Default settings.
Restore Default Settings
Choose Yes and click Apply to restore all Access Point settings to the factory default settings.
Thank you
Imran
Pls rank as possible
SOURCE: KyoceraMita KM-4050: System Board reset for authentication
Login with 5050 as the username and password via the web browser and turn off authentication.
SOURCE: How can i reset into
Push the blue Veo button on the front of the camera to turn it "OFF". Wait a minute and push it again to turn it "ON". This will reset the camera to the default settings: user; admin; password: password.
1. Turn off the router
2. Locate the Reset button on the back of the router.
3. Use a paper clip to press the Reset button and power on.
4. Hold for about 5 seconds (don't hold too long) and then release. (Or, release when M1 and M2 flash at the same time.)
5. After you have completed the above steps, the router will be reset to the factory default settings
Then open up the browser and type in 192.168.0.1
It will ask you for a username(leave it blank) and password (admin).
Once you are in the router setup, you can setup a new password.
Iām happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
