SOURCE: Porter Cable belt sander
try to rig the nozzle of a shop vac to the part where the bag would normally connect and run the sander simultaneously with vac for a few minutes and see if that helps
SOURCE: need a manual for a Craftsman belt & circular sander
I found a PDF file on Sears.com website for the original manual for my belt / circular sander.
SOURCE: looking for a manuel for a makita belt sander model #9401
There is a black metal ******** one side that is actually a lever and with the tip of a screw driver or the like, pops out and releases the front roller.
SOURCE: broken drive belt on belt sander
My answer comes almost a year after the original question, but I'll post it anyway for those who end up here after a search.
Black & Decker no longer supplies drive belts for the BR400 sander, but you can get a replacement elsewhere if you know what to ask for.
The belt is a synchronous, single-sided "XL" series belt, and mine had 120XL031 printed on it. The belt width is 0.31in or 5/16in or 7.9mm. Its pitch (distance from tooth to tooth) is 0.20in or 1/5in or 5mm. Its total height is 0.09in, and tooth height is 0.045in. It has 60 teeth, making the total length 12in.
I found a replacement at sdp-si.com, part number A 6R 3-060031.
Look here for timing belts (inch), then narrow the search for single-sided, .200 (XL) pitch, 60 grooves, 5/16 width.
SOURCE: Finding parts for Craftsman 4x24 sander model
craftsman belt sander just stopped - does craftsman still have life time warrenty?
