SOURCE: Grinding/Rubbing noise?
the unit has a "food chopper" inside the pump sump. it is to chop up "food" items and not bones, seeds or other items. you can keep running the unit and see if after 2 or 3 loads the noise goes away. ie: the item get chopped up small enough to go out the drain.
if it doesnt go away, then you will need to get into the wash pump and see what is stuck in the sump.
its not hard to take apart and you will find whatever shouldnt be in there.
SOURCE: Install feed rollers in ADF of HP scanjet 5590
You can get a service manual at this website address (HP website):
http://h10061.www1.hp.com/ccsearch/search?pname=HP+Scanjet+Scanner&qry=instruction+manual&submit.x=7&submit.y=4&ctry=emea_africa&lc=en&dlc=en&mode=fb&tmv=0&method=prodFinder&pid=&productBigSeriesOid=&spid=&opname=&pname_desc=&ptype=&stype=&contextual_lname=&spname=&temp_hql=&search=0
SOURCE: My Bissell Cleanview Bagless vacuum makes loud grinding noise.
the ends of the roller have something wrapped around them.see if you can pull the ends off so you clean the caps and bearings
SOURCE: hp 3055 adf
ADF problem. I put original in ADF, give a"COPY" command (READY on display), but scanner get image from glass, no from ADF. Can help me somebody?
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
