About how to move your contacts from old phone to new LG Fortune2, the easy way is using phone transfer software, if both of them in your hands. You just need to connect them to computer via usb cables, start the software. https://www.coolmuster.com/phone-transfer/contacts-transfer-from-old-android-to-new.html
Gmorn download google application and then backup the old phone then switch SIM card you have to download google to the new phone.
You can use ApowerTrans to move data from a old phone to a new phone. It's safe and easy to operate. ApowerTrans Transfer Files Between Phones in One Click
You can enjoy an one click transfer from Android to Android by using Phone Transfer software, which is a professional tool designed to directly and freely transfer files between two Android phones. With this tool, you can easily transfer any contacts from old phone to LG phone without any difficulty.
(1) After opening the installed software on the computer, get the two Android phones connected to the computer via two USB cords. Then you will see the below interface.
(2) Then you will then see an interface where different file folders are arranged on the middle panel. Click "Flip" button to change the side between Destination device and Source device if needed.
More: One Click to Transfer Files from Android to Android
If you have ever used an assistant program like MobiKin Assistant for Android to manage your Android data on desktop computer, then you must have noticed that this kind of program allows users to backup contacts from Android device to computer and restore these backup files to Android phone again, right? So, why don't you transfer contacts between two Android phones with this program? Sounds great, right? Now, you can try this program by yourself, but if your file manager tool have no function of restoring, you can take the recommended MobiKin program as your assistant and follow the below steps to reach your goal.
Step 1. Make Your Phone Be Recognized
Step 2. Export Android Contacts to PC
Step 3. Import the Exported Contacts to the New Android
How to move my contacts from old phone to new LG Fortune2
Ultimate Guide on How to Transfer Contacts from Android to Android
SOURCE: lg shine
I had the same problem! I just looked up in the manual and the shorcut is menu,8,7,3 to COPY all contacts or menu,8,7,4 to MOVE them (copy keeps the original contacts stored on the handset memory. Now because I can only view the botom right hand corner of my screen I can't be 100% sure what happened next. I pressed (enter/ok). Then could tell I needed to enter a 4 digit code as the layout changed so tried my pin and then 0000. I think 0000 worked and vaguely remeber it as a factory setting security code or summit. Hope it works for you too.
so again I think thats menu,8,7,3,ok,0000,ok......... then wait a few minutes while you imagine the bar scrolling along as the contacts a re copied (took about a minute and a half on mine so maybe wait 3 minutes just to be sure. switch off put ur sim in another phone and see if it worked
if not try your pin in place of "0000"
peace....
SOURCE: Copy Contacts to HTC HD
first tranfere the contacts from old mobile to outlook, then sinc the htc hd with outlook which tranferes the contacts to your hts touch hd
SOURCE: Transfer contacts from old LG phones to new Samsungs
Mobile Action Handset Manager works too.
SOURCE: my lg cu515 broke and I need to move contacts to sim
Red key (to make sure you're on the home screen)
Left key (menu)
3 (Address book)
5 (Copy All Contacts)
2 (Handset to SmartChip)
1 to Keep original, 2 to Delete original (I'd keep it, just in case this doesn't work)
(Beep)
1 (Yes to confirmation)
Wait for another beep
Done.
SOURCE: my old phone contact need
You have not stated the Brand and the Model of your old phone.
anyway the basic procedure remains the same for every cell phone.
Transfer your all contacts in the old phone to your sim card.
Go to phone book/address book and then contacts.
On the drop down menu you will find 2 options i.e. Copy Sim to Phone and Copy Phone to Sim.
Click on Copy Phone to Sim.
All your contacts will be transferred to Sim.
Remove the sim from the old phone and insert it in the new LG phone.
Repeat the above steps.This time you have to select Copy Sim to Phone.
All your contacts will be stored in the new phone.
