Probably need the manual for the clock.
SOURCE: I need a Howard Miller battery mantle clock
Try www.klockit.com. You can replace the entire movement for about $5 including new hands. You can select from an assortment of hands that will probably match the style of what you have and use those if the old hands don't fit the new movement. I've bought several movements from them over the years. For a few more dollars you can upgrade to an "atomic clock" movement which synchronizes with the US time signal and even sets DST automatically.
SOURCE: I need to find a
First of all, here is the main Howard Miller Online Support and Download page with the links to the instruction manuals for all their clock models:
http://www.howardmiller.com/webapp/wcs/stores/servlet/GenericView1?langId=-1&storeId=12652&catalogId=13551#floorclock_inst
And here is a direct link to the ONLINE USER'S MANUAL for the Radio Controlled Clock model:
http://store.howardmiller.com/wcsstore/HowardMillerPublicSite/Attachment/625236_PD10727.pdf
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, the follow the onscreen instructions to install the software on your computer.
Please comment back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
Joe.
SOURCE: how to operate howard miller clock 645-342
Make sure all winding springs are wound well- but not overly tightened and set pendulum in motion. The clock needs to level across the face and front to back to work correctly. Time can be adjusted by moving the hands of the clock via the minute hand- allow it to strike once at each strike interval to keep strikes synched to clock time, and fast or slow can be adjusted by either the adjustment onthe pundulum arm or on the mechanism where you see an arc with "F" and "S" on either end.
Depending on model, it will need winding at least as often as the name of the clock type- in other words, a seven day clock should only need to be wound every 7 days.
Hi Pam,
I have a Howard Miller Grandfather clock and the pendulum swings very slowly and from far left to far right travels only about three inches at best. It doesn't need to move any more than that to make the "Verge" move the "Escape Wheel" to rotate the gears to keep the hands moving at the correct tick. Howard Miller Grandfather Clock
