All else is working except the battery is not charging.How do i get the battery to charge? it has 38% charge on it.
SOURCE: toshiba satellite battery charge problem
You could ask for a replacement if the computer is still in its original standard limited warranty.
SOURCE: toshiba 1410-S173 battery charging light blinks amber
did you buy the battery brand new or used?
brand new, deffectibe motherboard, bad charger or bad dc socket.
used, change it.
SOURCE: Toshiba A135-S4527 laptop ** Battery not charging!
Check the power input jack soldered connections for cracks, resolder them as necessary.
SOURCE: Toshiba Satellite A15-S127 won't power up
here is a complete list of bios code...
http://www.pchell.com/hardware/beepcodes.shtml
you will need to find out what BIOS chip is on the mobo...
hope this helps you out, when mine did it, it was much easier than this i found a bad connection at the power plug.
SOURCE: Toshiba Satellite m305-s4910
remove the battery pack and power source. make sure nothing is plugged into the laptop. hold down on the power button for 30 seconds. then reinstall battery, plug the the adapter into a known live power source (the real reason for your problem) and power it up!
Testimonial: "Make sure that the power supply is charging. I will suggest you to buy an universal charger if possible to test it. I will also want to point that the problem may lay on the memory himself, try to remove both if there is two and try one at the time."
