Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Washer drum bearing bad, how do I replace it?
  • 38 Answers
Pull the agitator out and make sure its not just a broken bolt, There are two bolts that hold the basket assembly in place on the transmission crank.
Posted on Sep 27, 2009
6ya staff
SOURCE:
Washing machine vibration
I had same problem. It was actually wearing out the rubber gasket on front door. It ended up being the spider on back of drum. They corrode pretty good with the front loaders.
Mar 28, 2014 | LG WM1814CW Front Load Washer
My washer is making an awful noise and it wont spin like it suppose to what is wrong
your inner drum bearing lip-seal has gone bad and the inner drum bearings are now water soaked and rusted and need replacement,parts are cheap,but depending how long it takes to remove and clean the bearing races and time/labor you will need to check on in your area
Apr 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My maytag washer model #sav5710aww shakes badly and
if its a neptune front load washer you need new tub lip seal and bearings for the drum as the seal is leaking water into the bearings that hold the inner drum,it will only get worse,you need to remove the inner drumto replace the seals and bearing it takes from 2 to 6 hours depending how hard the old bearings come out of the race
Apr 02, 2010 | Washing Machines
Progressively louder on spin maytag neptune model# MAH5500BWW serial#C8028996LC
You have a bad rear drum bearing ( unfortunantly , so do I ) . This involves removing the inner drum and outer drum . The complete rear of the outer drum , has to be replaced , due to the bearing is already installed in the new one . Very expensive to have done and very time consuming to do yourself . You probably should invest in a different washer . Front load washer manufacturers , have not come up with a way to support the front of an inner drum as well as supporting the rear also . Until this happens , rear bearing problems and excess expense for repair , will continue to be the downfall of front loading washers .
Nov 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Loud clunking sound during the spin cycle, washer is balanced and on 2nd floor
If you get a very loud noise coming from the machine, and this noise islouder when it spins faster, then it is often because of a problem with the drum bearing.
The drum bearing is bad, probably drum bearing spider had broken.
On a front load the drum bearing is located at the back of the drum.
To replace the part you take apart machine, undo the belt and depending on the model you may need to remove more parts.
You can find parts and diagrams for most models here.
Nov 13, 2009 | Frigidaire GLTR1670A Front Load Washer
Sounds like a Harley when it spins, still spins though.
If you get a very loud noise coming from the machine, and this noise is louder when it spins faster, then it is not a Harley inside your washer, it is the drum bearing.
Nov 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Loud spin noise from Maytag washer
Check the drum bearing, a load noise, and often spinning problems are symptoms of a bad drum bearing.
Jan 05, 2009 | Washing Machines
I have a top load Roper washer that won't spin.Any ideas?
That sounds like a bad drum bearing, check and eventually replace the drum bearing.
Dec 28, 2008 | Roper RAS8445KQ Top Load Washer
Bearing noise
rear bearing is pressed into outer drum never changed bearing only usually requires entire drum replacement instead..also shaft on rear of inner basket is probably scored bad and needs replacement too
Mar 20, 2008 | Maytag Neptune Washer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
196 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
