Maybe a bad seat switch. Try leaving the brake on and starting the blades .. If that kills the engine too, I'd really be eyeing the seat switch
Testimonial: "Thank you for the solid advice!!! It was the seat switch!! Where do i buy these switches too?"
The official site is herehttps://www.troybilt.com/equipment/troyb... ....
but also here's one place I've gotten great service from ...https://www.jackssmallengines.com ...
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
SOURCE: Troy-Bilt Briggs & Stratton 550 restarting
Troy, Unless you are using old fuel (it breaks down after 1 week) it sounds like you have a faulty spark plug. Replace this first, drain any old fuel and replace with fresh fuel (premium unleaded). A faulty plug will work one minute but then fail like you have described.
SOURCE: troy bilt pony riding mower will go in reverse but
have a troy-bilt riding mower. place a gear in neutral and park it.
it dies instead idling. want to know why?
SOURCE: Troy bilt mower ran fine then died and now it wont
Remove the air filter and set aside.
Take a can of carburetor cleaner and spray the inside of the carburetor.
Let it set for a moment and then try starting the engine. It should run a few seconds. Repeat. When it starts squirt a small shot of cleaner in the carburetor to keep it running. That should remove the varnish the gas leaves as it evaporates over the winter.
If it still won't keep running then there is trash in the float bowl plugging the needle valve seat and the jets.
1) Turn off the gas or remove the gas line and plug it with a small screw or stick to keep it from leaking out of the gas tank.
2) Look on the bottom of the bowl for a nut .
3) Remove the nut and drop the float bowl.
4) Carefully remove the pin holding the float and needle valve assembly.
5) Take the carburetor cleaner with the straw it comes with and spray every hole in the carburetor to clean the jets . (up through the needle valve seat, down top of the carburetor , see a hole, spray it with the cleaner.)
6) Clean the float bowl.
7) Reassemble and make sure the gas isn't leaking and try to start it again.
