Question about Powermatic Saws
HOW TO REMOVE THE POWERMATIC TABLE SAW MOTOR - Powermatic Saws
6ya staff
SOURCE:
Anonymous
SOURCE: Need a rocker switch for
If you want to buy a new one, the Grizzly G1022 Table saw is an exact replica of the PM#63. A owners manual and parts list is available at their website. Grizzly.com
Posted on Apr 12, 2009
Anonymous
SOURCE: My Powermatic 66 table saw won't start.
Your saw motor is equipped with a two speed internal start switch. Over time saw dust will get into the contacts and cause the points to burn. You can pull the end off of the motor and take some 400 grit sandpaper to the contacts to clean them( there are two sets of contacts one works in the out position the other in the in position) it will be the set in the in position that is the problem. Gentle clean them, reassemble the motor end cap and it will work fine. I have to do this about once a year to my saws. I use my saws about 25 hours a week. I have been doing this to one of my Powermatic saws for 31 yrs. now.
Posted on Jul 29, 2009
Anonymous
  • 70 Answers
SOURCE: vibration in powermatic model 66
No. Unplug saw remove saw blade grasp shaft that saw blade was on wiggle back and forth. Should not be too much play. After 10 years motor bearings are proably worn. Easy to replace
Posted on Aug 07, 2009
Anonymous
SOURCE: Manual for Powermatic model 70 table saw
Did you try Powermatics web site?
Posted on Aug 23, 2009
Anonymous
  • 9 Answers
SOURCE: Table saw capacitor heats up and explodes.
The wrong capacitor for one thing. There are starting caps and running caps. The starting cap is in the circuit for only long enough for the motor to get up to speed. If you have a Leeson motor that has a start and run cap then the run cap may not be the correct on. If you have a start cap blowing out I suggest you check the centriifugal switch in the end of the motor. It may have welded the contacts shut. In any case, I would take it to a motor shop .
Posted on Apr 04, 2010
I have a Powermatic 2000 table saw. The power is good but the saw won't turn on. It has a magnetic switch with a double of circuits inside. do I need to replace the whole switch assembly ($172) or is there...
prob just motor starter. remover power from mag sw and o/l from bottom of mag sw. meter L1 to T1 for continuity by pressing button in center of mag sw. do this for all L1,@ and # to T1, 2 and 3. if all good check for resistance in coil..A1 to A2. replace with new by taking part to electrical wholesalers.
Dec 15, 2013 | Zazzle Powermatic 2000 Table Saw T-shirts
Powermatic 66 wiring problem
Simple solution: switch two of the wires. Doing so will reverse the direction of the motor. You can switch it at the motor or on the electrical plug end.
Mar 28, 2013 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
I have a powermatic 66 table saw. I removed the motor, to move the saw. when i reinstalled the motor, the blade has moved 5/16'' towards the fence.
Check to make sure the arbor set screw is not loose. The bearings may have shifted when you moved it. I recently rebuilt an old 66. Repositioning the bearings and tightening the set screw could be all it needs.
Sep 27, 2011 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
I have recently purchased used powermatic 66 Table
That is the current setting for a motor-starter which is an overcurrent sensor. This is a circuit breaker like device that usually has a heater coil that opens a contact which cuts the power to the relay that powers the motor to prevent overload damage to the motor.
The dial is in AMPS and should be set just slightly higher than the nameplate amp rating for the motor.
Oct 24, 2009 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
I have a Powermatic 66 that trips breaker
Either it has a problem with a blade brake or the motor is siezing. Or the is a wiring problem. With the unit unplugged check and see if you can turn the blade by hand, if not the motor is the problem. If it does you could still have a motor problem by it drawing to much amperage or the is a wiring problem.
Aug 31, 2009 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
Aug 16, 2009 | Saws
Vibration in powermatic model 66
Aug 07, 2009 | Powermatic 1660802K Model 66 Special...
My Powermatic 66 table saw won't start. Tried to turn on my Powermatic 66 table saw this morning. Blade moved one half inch as if trying to start. Tried reset button on motor, still nothing.  I...
Jun 08, 2009 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
Mar 11, 2009 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
Saws Logo
270 people viewed this question
Top Powermatic Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Raymond Richards
Raymond Richards
ray gallant
Are you a Powermatic Saw Expert? Answer questions, earn points and help others
