SOURCE: ICVG convection oven shut down during cooking process
Wrench, clearly something is causing them to do what they do. Best I can give you are thinking points.
Does this happen every time?
Is there something else on the circuit that could cause undervoltage?
If the hi temp is tripping, why? Put a thermometer in the oven and see where it is.
Get the factory guy on the phone.
SOURCE: Error F3 on display ovens beeps
the temperature probr is located inside your oven in one of the upper corners. it should be a round stick looking piece. some are removed from the front others are removed from the back.
SOURCE: F1 on frigidaire stove
Most F1 codes for frigidaire state bad EOC (clock) but the temp sensor is the least expensive place too start.
SOURCE: oven temp gets hotter than control indicates.
Alot of the thermostats are adjustable and can be recalibrated but when they act like this, it is best to replace them. It is just a matter of time before it quit all together. Electronic units are some what different.
Let me know what you do and I'll give you a hand in getting it going.
SOURCE: my oven temperature is 100 degrees hotter than it should be
It will be the sensor inside the oven compartment that is causing the problem.
A new sensor should cure the prob, certainley cheaoer than buying a new oven.
Hope my advice helps you.
Testimonial: "Thanks, I will definitely check pricing and installation costs for this part."
