Ive cleaned the bobbin area/case and its threaded correctly but the thread from top breaks within 3 sticthes. is it the tension? its set on 4
When it stitches, does appear the top thread is tighter and pulling the bobbin thread up? Pay attention to what is happening before the thread breaks. Sew slowly and manually turn the handwheel. Where does it break? What are the symptoms before it breaks? Does it fray/shred at the needle eye? (The thread is not advancing through the needle eye properly and is actually being shredded, could be the needle has a sharp spot or the needle eye is too small for the thread. Coarse fabric will also shred thread.) Do you notice the top thread getting tighter and tighter and then finally popping? (The thread is being held back somewhere in the thread path {misthreading'--happens to me when it gets wrapped around the spool pin or a thread guide.)
Suggest removing the top thread completely from the machine. Install a brand new needle that is the appropriate size and type for the thread and fabric. Remember to ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct. Adjust the top tension until the top and bobbin threads meet in the middle of the fabric.
Why is my thread breaking
https://www.howcast.com/videos/512591-why-does-my-top-thread-keep-breaking-sewing-machine
http://www.servicethread.com/blog/stop-industrial-sewing-thread-breaks
SOURCE: Bobbin thread breaks
Make sure your bobbin thread is turning clockwise as it sits in the bobbin case. There is a screw on the outside of the bobbin case you can turn with your thumb slightly to adjust tension. If you dangle the case from the thread and give it a light ****, it should move down slightly when doing so-an indicator of good bobbin tension.
SOURCE: I have a Janome 6500
is the needle god it might be bad and have a sharp edge thats braking the thread?
SOURCE: bobbin thread breaks. sounds like clicking while sewing
hi there,
pls, the see the figure how bobbibs thread directionhave you seen theres a screw on latch body case of bobins,you can adjust this but mostly this is factory
adjusted,bobbin tension can adjust here.but try to follow the thread direction.set up again the dial setup tension to #3 and stitch to #8 to #12.bobbins slip due to accumulation of thread under
bobbins.hopefully this may help you to continue sewing.
have a nice day,
SOURCE: my Husqvarna diamond top thread
Hello
Primary causes of upper thread breakage:
-- misthreading: pull all the thread off and thread again, using the manual, step by step. Read each step aloud before you do it. (sounds dumb, but helps.) (And make sure you thread the takeup lever!)
-- thread has wrapped itself around a thread guide or spool pin from one of the breaks. Take the spool off the machine before rethreading.
-- bad or damaged needle. Replace with the right size for the fabric, turned correctly (backwards needles skip stitches)
-- dirty machine, especially in the bobbin case area: review cleaning instructions and do it, using brush and vacuum only
-- bad/cheap thread: should not be slubby or break easy. Try another spool.
-- top thread tension too tight. 4 is normal for most fabrics, most stitches.
Tips;
1) do a light cleaning (brush and vacuum) every day you sit down to sew.
2) replace the needle if you hear it hit metal, if you've got a really bad thread jam, if you see it deflect as you sew (for instance, sewing over the side seam on jeans when hemming). Replace every 3-8 hours of actual stitching time anyhow.
3) buy good quality thread
4) when your machine isn't sewing right, stop; take all the thread off of/out of the machine (bobbin out of bobbin case, spool off spool pin) and give it a quick cleaning. Rethread from scratch, carefully. If that doesn't fix it, do it again, then replace needle and rethread one more time, manual in hand (yah, even if you've threaded it 8 million times before). #4 is curative about 98% of the time. The other 2% often requires professional attention.
SOURCE: The top thread continues to
I have 2 singer sewing machines and whenever the thread is breaking like that i find that I have to RE-THREAD the machine sometimes SEVERAL times until I can feel the thread give a little bit while its in there & not breaking! It's very frustrating but just keep rethreading from the beginning where you put the spool on your machine & sooner or later you'll get it right & it will work! GOOD LUCK!
