SOURCE: my washing machine will not spin or agitate
Does the washing machine empty as normal? I am assuming it does and think the brushes on the motor could be worn. Hope this helps.
SOURCE: washes but won't spin or drain completely unless no clothes in
Hello screenman780
I will assume you are taking dc or UC errors to the display in spin cycle. Just need the first two digits of your machine serial number, ie. 10,12,16 etc. That information is located on the right back side of the machine console. If you are taking those errors I recommend removing the clutch inspecting the clutch roller bearings and clutch spring. There is a test to perform for the Tub Displacement Sensor that we could check first but 10 times out of 10… so far it’s the clutch. Most of the time a cleanup with WD-40 and re-lube of the clutch bearings with some light bearing grease will get you back in service. If the clutch bearings are rusted up beyond clean up or the clutch spring is broken then a clutch replacement will be required. I recommend this clutch as a replacement. I put that clutch in my machine (1st two digits of my s/n are 16) just to make sure it would work, my original clutch was cleaned up with WD-40 alone and worked as the day delivered on 7/05. Take a look and read thru the post in the link below. In that post I go thru a step by step process to replace the clutch (comment of 3/18). I can also offer some phone support no charge; I'm a DIY'er owner of the machine. I believe the repair cost (from previous post on this forum) to replace the clutch and labor will be around $300 if you don't DIY the repair/maintenance for this issue. Most of the clutch malfunctions are resolved with the clutch maintenance. Anyone can do this with only basic mechanical skill sets. If you can change the spark plug on a lawnmower you can deal with this, the work area is just tight. Here are some folks that had positive results with this maintenance. Unfortunately I feel many of these machines end up at the curb for bulk trash pickup when a $10 fix for some WD-40 a squirt of bearing grease or worse case a $50-$60 new clutch replacement. Good Luck and let me know if you need additional support, Rich.
http://www.fixya.com/support/t527875-maytag_neptune_tl
Here are some folks that did this maintenance with positive results.
Positive Fix1/19
Positive Fix 1/18
Positive Fix 3/4
Positive Fix 3/4 different Forum
Solution #4 posted on Mar 17, 2009
SOURCE: IFB Bosch washing machine.
I have an IFB washing maching it does not spin dry the clothes any solution
SOURCE: My kenmore top loading washing machine won't spin
Once you remove the cabinet,remove the water pump and check it for a garment or lint. Clean or replace the water pump and reinstall it.
