Instructions on removing the back case of the audiovox cd-505slk
SOURCE: Removal of front cover
To remove the front cover you need to start by putting the monitor down flat on its face on something that wont scratch the screen.
Next, remove the screws holding the base to the back of the monitor. (You might need to remove a plastic cover to get to the screws).
Once you have done this check for a screw under where the base was screwed on. Remove this screw.
Now check the back of the monitor for one screw in each corner. Not all models have these 4 screws,if they are there, remove them.
Now the front and back of the monitor are held together with plastic clips. You will need to gently pry the front and back apart.
Its easiest starting at the bottom middle and working around.
Once you have separated the front and back, the inner circuitry is exposed. The control panel for the unit can be removed by unscrewing 3 screws that hold it in.
SOURCE: Take the back cover off a LCD Television
Take out all screws around the outer edge and the smaller screws just above your video conections and dont forget the 6 large screws for the mount in the center. It should just lift off.
SOURCE: remove case
In the tires, there are plastic lugnuts. Remove the plastic lugnuts with a pair of tweezers (be careful, they are pretty brittle and tend to break). Once there, the screws to remove the tires are exposed. These are just trim, but you need to remove them to get to the screws holding the case on. Next, there should be silver screws holding the fenders on. Remove those. Now all the screws holding the case on are exposed. Once you remove the case screws, remove the two tiny screws on the back where the A/V connectors are at. Then the case just slides right off.
SOURCE: Removing Battery cover for cell phone
There are so many models out there and many different ways to remove battery covers.
Besdies the brand I also need the model of the cell phone in order to tell you how to remove the cover.
Try looking up the model from the place you purchased the phone from, if you purchased it online you most probebly can find the model number in the description of the listing.
