SOURCE: ignition coil for 1993 civic
best way to test is connect to car and see if it gives spark with engine turning, because it gets ground pulse from the distributer,if pulse id not coming to ignition coil, then you need to change distributor.
SOURCE: i have yamaha gladiator. it's ignition system is
This is because of the malfunction of the alternator or the rectifier section. You check the same to terminate such a issue.
SOURCE: my 2004 ttr 225 yamaha
it has to be 12v. the bike runs on a 12v system. before u check the cdi. check the plug. and the gaping. i had the same problem but it was the pulse coil. the ttr 225 is more of a beginer bike it comes from the factory very lean. so it might not be that you have a low spark because they are not ment to be fast they just have a low spark from the factory. check your carb and the jets. that might just be your problem. let me know how it works out.
SOURCE: poor spark,what should the ohms reading be for the
XL 185S HONDA 79 MODEL EXCITER COILS OHMS SPECS ?
