SOURCE: Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
SOURCE: Duet Gas Dryer- burning smell
first is first ,,, disconnect dryer from plug,, now open bottom panel 2 screws ,, now go and get youre vaccum,shop vac, anything ,, reason for burning smell ,, usually catching on fire ,, we recommend do this 1 as year,,, after cleaning , put about 2-3 fabric sheets inside dryer and let it runn for about 30 minutes to remive smoke from drum,,, thank you
SOURCE: light soot around propane fireplace vent
burners burning yellow , in complete combustion , blocked air ways to burner , it needs a service soon as poss
SOURCE: Dometic/Duotherm propane furnace won't fire up
If this unit has a spark ignition you may just need to clean the flame sensor. It is a metal rod protruding in the path of the flame.
SOURCE: Just bought a tent trailer with a Dometic Fridge.
You need to make sure that you follow the manufacturer's recommendations for using the unit with each specific power source. It's important that you have the all switches in the proper position, based on what power source you're using.
Here's the manual for your model, save a copy and print it out and take some time to review the section #3 Operating Instructions on page 6.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Hope you find this helpful and will resolve your issue.
