My system is dvd home theater system HTS6515 philips everything was fine until I got back home I wanted to play some music and couldn't turn it on anymore the only thing I get is red standby tried several things no success :( please help me
Contact Philips on their web site for assistance or pay a local repair service technician:
https://www.philips.com.sg/c-p/HTS6515_98/-/support
Visit the support page for your Philips DVD home theater system HTS6515 98
https://www.philips.com.sg/c-p/HTS6515_9...
Problem is not listed on page 48 Troubleshooting of guide.
https://www.download.p4c.philips.com/fil...
SOURCE: Region Code
1. Press DVD "OPEN/CLOSE" key on remote Control (R/C) or main set to open the DVD door (note: if no disc on tray, then no need to open the door);
2. Press R/C numeric key sequentially 9735 (entry code, no display on TV), enter DVD region code setup menu.
3. Press R/C "down direction" or "up direction" key to change REGION CODE,"0" is all code.
4. Press R/C "OK" key to confirm.
5. Press R/C "SYSTEM" key to exit DVD system setup menu
SOURCE: red picture
Only thing I could think of is check your Pscan on your players make sure the correct setting is set for Progessive Scan and the other thing is a common Did you check the cables ??
SOURCE: how to play music on pc on home theater system
hello. i was just looking over the panasonic manual for your system and it doesnt look like there is any extra inputs to hook anything up. i think from what i was looking at the home theatre system has fm radio on it right? what i do sometimes is use a wireless fm transmitter that i have and plug that into my laptop and set the radio to the station the transmitter is set to. it works ok. you can get them at radio shack and best buy and places like that. let me know if that helps
SOURCE: I have pretty much the same problem that everyone
I did it tonight, worked on the Akai for two hours. I don't have any electronics experience and just followed what these guys did and spent less that $20 for parts and supplies from Radio Shack. Bought three different capacitors, mine was 1000uf 35wvdc 85+, a solder kit, and a desoldering vacuum tool. My soldering wasn't the best, actually the worst I have ever seen but I figured if it doesn't work, I could care less anymore. Apparently it worked. My first TV fix and i made it work! Follow the instruction here: http://www.fixya.com/support/t1661054-akai_lcd_tv_power_light_stays_red_turn
