SOURCE: iNGROUND pOOL 8.0M X 4.5M sAND fILTER onga psf25
Its either clogged or overheating or internal fault . Do you have to press the red reset button each time.If so there is a fault with the motor and will need to go to electric motor specialist.
SOURCE: onga smh45 tripping rcd
Check the electrical connection for grounded wires or
loose electrical connections. Use wire nut for all electrical connnection and tape it properly. This should
correct the 20 ohms earth leakage. Send you e-mail comments for further assistance.;
SOURCE: pump cut out. primed pump and restarted but keeps
Here is a tip that will help you..
Jet Well Pump Well Jet Water Pump
http://www.fixya.com/support/r3695577-jet_pump_jet_water_pump
heatman101
SOURCE: Have an Onga JJ400 jet
Is the pump building pressure and shutting off? If the pump keeps running but not building pressure than there is most likely a problem with the well (low volume). Also check for a water logged bladder tank.
RJ
