Maybe one of these will help
https://grocelremu.files.wordpress.com/2015/07/noma-air-conditioner-instruction-manual.pdf
https://36003606.r.bat.bing.com/?ld=d34KT57LJ0tUiYHI-BYJNXgDVUCUwMaeH3eas9PzfN8sK0ctwjjxA_SGsC3YbtrZ7A8XgHbTofKfumGzv6bj_tsoYjmsKUDT35SRjuTvJ8ony_Agdbh7-k6m88gN_EJUQ1flB8Os2emUBgj-mEb40KM0-zw4bRsXsFuuzkEFWbX9iYPl35&u=http%3a%2f%2fwww.findproductmanuals.com%2flp%2f%3fbrand%3dNOMA%26utm_source%3dadcenter%26utm_medium%3dcpc%26utm_term%3dnoma%2520manual%26utm_network%3do%26utm_campaign%3dFPM%2bMB%2b02-26
SOURCE: Need to know the watts on a Fridaire Air Conditioner 6000 btu
check your name plate voltage and current rating, multiply it and the result is the wattage of the unit.
SOURCE: air conditioner window unit {Hampton Bay}
You can get the parts from the below sites:
www.searspartsdirect.com
www.partstore.com
If you need anymore help let me know.Please don't forget to rate or accept the previous premium solution.
SOURCE: My Haier 5,200-BTU Window Air Conditioner keeps freezing up.
You need to clean the unit outside(take it out of the window) with a water hose because it is dirty inside( you have to remove screws on cover and take cover off), be sure to cover the electronic control board with plastic so you don't get it wet.Clean fins on front and back with water hose and inside .
