Televison & Video Logo
Tim Tuffield Posted on Jul 13, 2018
I need a remote control for a Proscan PLDED4016A-H. I can find several plded's at amazon or ebay but none that end in a-h. Can you help.
5 Related Answers
pdiggs
  • Posted on Feb 24, 2008
SOURCE: remote control not working and need programming code for cable television/universal remote control
remotes.com says oerseas item-not available?
Anonymous
  • 86 Answers
  • Posted on Feb 15, 2009
SOURCE: Need DirecTV remote code for Proscan 26LB30QD
Direct TV Remote Codes for various devices.
Anonymous
  • Posted on Mar 20, 2009
SOURCE: I have tried to program my FiOS Verizon remote
Thank you. I did solve my problem with some diligence. The instructions from Verizon were correct. I realized that there are two buttons on the Verizon universal remote that look alike - the "play" arrow and the "fast forward" double arrow. Once I used both of these buttons in the proper sequence, reprogramming the TV remote with the new code worked.
Anonymous
  • Posted on May 30, 2009
SOURCE: need a remote control code
hi,i had the same problem and found out that the samsung remote codes worked,try that.
Anonymous
  • Posted on Jan 18, 2010
SOURCE: I need the remote control code for Proscan tv with dvd player
Don't know if the 26" is the same as the 32, but 10019 works for the 32".
How to retune an Alba AELKDVD2288PK without a remote control?
All televisions need a remote control for advanced options. A new one is $17 on eBay or Amazon or the Remote Control website.
Genuine Alba AELKDVD2288PK TV Remote Control
eBay https://www.ebay.com > ...
Save on Remote Controls ; DIRECTV RF-XMP RC66RX Universal Remote Control. $9.95. Trending at $16.98 ; NEW Replacement BN59-01259E Remote Control for Samsung Smart ...
Classic Replacement Remote Control for Alba ...
Amazon UK https://www.amazon.co.uk > Replacement-Control-AE...
This Classic remote control is a replacement for the original Alba AELKDVD2288PK remote. The Classic remote will operate all the functions of the original ...
£17.94
https://www.google.com/search?q=Alba+AELKDVD2288PK+replacement+remote
1helpful
How can I connect a Proscan PLDED4016A 40 LED TV, With a Phillips soundbar HTL1520B?
Can you access all of the ports on the ProScan PLDED4016A? There are some ports that face down (near the power cord) and others on the right hand side (as you face the back). The picture from the manual, https://www.manualslib.com/manual/1049754/Proscan-Plded4016a.html?page=8#manual , indicates a headphone jack and a coax audio output and analog RCA audio out. The headphone jack is at the bottom of the side input area below the component video and service port. The digital Coaxial and RCA Audio outputs are closest to the power cord.
The PC Audio port is an input when the TV is used as a monitor with a VGA connection to a computer. See https://www.manualslib.com/manual/1049754/Proscan-Plded4016a.html?page=12#manual for using the TV with headphones.
If the headphone jack doesn't work, you need some sort of converter or adapter. To use the TV's digital coaxial audio port with the optical digital audio port on the sound bar, you need something like this: https://www.monoprice.com/product?p_id=2947 . Note: make sure to get the correct input and output option; these are not bidirectional. You will need to supply the RCA digital audio cable.
For the analog RCA audio output on the TV, you have multiple options. A simple RCA (M/M) to 3.5 mm (M) cable will work. So will various RCA audio/3.5 mm adapters, depending on where you want to put the adapter. (RCA (M/M) to 3.5 mm (F) is the simplest since you have the Aux cable.) These will connect to the Aux in on the soundbar.
You can also use an analog to digital audio converter, https://www.amazon.com/Musou-Digital-Optical-Toslink-Converter/dp/B01HGHNCMW . You'll need to supply the standard analog RCA audio cable for most of these. Then connect the converter output to the optical audio port on the HTL1520B.
I hope this helps.
(Years ago, the 3.5 mm to RCA cable was often in the accessories for connecting a portable CD player to a stereo system.)
My dish remote will not turn on my proscan tv so a bought a rca universal remote and it turns the tv on but messed up everything else , so now I can’t get any channel s or pictures at all
Check the Source or Input button. You have accessed a source that has no input signal.
No one buys Universal remotes these days, you buy a facsimile remote that is an exact copy of the old one.
Proscan TV Remote Controls - Replacement Remotes
www.replacementremotes.com > Proscan > Remote-Con...
ReplacementRemotes.com offers Proscan remote controls for sale online including remote controls for TV, TV/DVD Combo, Sound Bar System and many more.
proscan tv remote - Amazon.com
www.amazon.com > proscan-tv-remote > k=proscan+tv...
Results 1 - 16 of 195 - GE Universal Remote Control for Samsung, Vizio, LG, Sony, Sharp, Roku, Apple TV, RCA, Panasonic, Smart TVs, Streaming Players, Blu-ray, ...
Proscan TV Replacement Remote
www.remotes.com > proscan-remote-controls-s
Replace new & discontinued remote controls for Proscan devices with fully programmed remotes from our online store. Enjoy low prices and fast shipping.
Proscan Remote Controls - Walmart.com
www.walmart.com > ... > TV & Video > TV Accessories
Products 1 - 40 of 43 - Shop for Proscan Remote Controls in TV Accessories at Walmart and
No picture on my pros can tv PLDED4016a 40 in
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
I HAVE A COMCAST ALL IN ONE REMOTE BUT I NEED THE CODE FOR THE TV IT IS A PROSCAN MODEL:PLDED4016A
0094 0154 0170 0190. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls.If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts. Search the sites by type in the brand name to your device, in its search box.It will help you to find the document easily.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
1helpful
Remote code for comcast remote
Visit the site named 'Electro-help' for more details. Click this link. View it in Timeslide or Flipcard option, which can be selected from the drop down box menu by the Sidebar tag, at the top left corner of the display window. You can also click the Home tab to see the latest updates. It will make search easier. There are more than 1450 posts to different brand TVs till now. Setup proceedings and code list to different brand remote controls also included. Pull up older posts or do a search by type in the Brand Name of your device in the Search Box, at the top right of the display window. This site too have code list.
I bought my 19" Proscan LCD (19LA25Q) used from a
The Proscan 19LA25Q came with a remote originally. Unless the IR receiver has failed, it should work with a universal remote. (Note: if the TV is newer than the remote (or released less than 6 months before the remote was programmed), the remote codes for your TV may not be included.) Since the code lists on universal remotes do vary depending on the age and model, please give more information than just the brand. GE remotes usually have a version code label in the battery compartment. This version code is needed to look up the correct code lists. Some GE universal remote built by Jasco codes are here: https://byjasco.com/support/ge-universal-remote-codes.
The Proscan 19LA25Q was probably built in 2007, since there are reviews from 2007. That was also the year when this size TV had to have an ATSC tuner. So if your remotes were programmed before July 2007, they may not be compatible. Some of the current Proscan TVs probably use the same parts as some Sylvania, RCA and Curtis TVs.The 19LA25Q was warranted by On Corporation which has control of the RCA brand now. However, I don't know when they bought the label.
Amazon lists a few direct replacement remotes for the 19LA25Q. See https://www.amazon.com/Original-Proscan-Control-E20F-19LA25Q/dp/B00KQVDRNK and https://www.amazon.com/PROSCAN-Replacement-Remote-Control-19LA25Q/dp/B009H5QVIO . Remotes.com also has a replacement remote: http://www.remotes.com/SearchResults.asp?Search=19LA25Q .
I hope this helps.
What remote do I buy for the Proscan LCD 26lb30q?
Try Ebay they have them the item number is 350167917823 just type that in the top where you would put in what you want to find.
Top Proscan Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
