It will start washing but stops and sends code of F 20 and starts to drain.I use to could unplug it & wait a few seconds then plug it back & it would restart but now it will not do that.
He f20 (or fh) error code on a Whirlpool Front Load Washer is an indication of a water supply issue. To remove the f20 error code from the display panel, press Pause/Cancel 2 times. If that did not clear the error code, see below for what may be wrong
heres a link...https://removeandreplace.com/2016/01/12/whirlpool-washer-error-code-f20-troubleshooting-front-load-washing-machine/
SOURCE: duet washer WFW9200SQ00 display F20
"F20" is a water inlet problem. This indicates that you have no water or insufficient water supply. What Whirlpool recommends to do is unplug the washer and check your water inlet screens to ensure they are not clogged, check the inlet hoses for kinks, and to make sure your taps are turned on (duh! I know it sounds stupid, but I've seen it before).
To check the water inlet screens you will need to turn off the water supply and disconnect the hoses where they connect to the back of the washer. The inlet screens are located inside the tap fittings and sometimes will collect with sediment and rust depending on your water source. Some hoses also have sediment screens. Check them as well if you have them. Use cotton swabs to clean the screens, thoroughly.
Checking the hoses and taps is self-explanatory. The water supply coming into the washer should be at least 10-25 psi. Insufficient water pressure can cause problems with slow fills and/or error codes due to insufficient pressure. If you haven't had any problems before, I would suspect dirty inlet screens and/or a inlet valve failure.
If you need to replace the water inlet valve, searspartsdirect.com carries the part. Just type in your model number in the Search menu and look for item #1 under the "Dispenser Parts" heading (part #8182862). The part runs about $52.00.
I hope this helps you. If you need further assistance, please post back with any questions/concerns you may have.
SOURCE: "F" error code in WTW6600SG1 Cabrio Washer
inside the control board panel or taped inside of cabinet wall are the tech sheet with trouble code definitions and procedures to trouble shoot washer
SOURCE: when washing stops and flashes f20
That code means "No water or Insufficient water supply" Check the water supply valve, the fill hose screen for debris... Good luck let me know if that solved it..
SOURCE: Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
[email protected]
Washer Not Filling:
If the appliance is not accepting input from the control panel, follow the steps below to reset the control:
