Please Help me to solve this problem.
SOURCE: xerox error code u1-1 main motor fault
You will need to replace the main drive motor assembly.
That stepper motor is a common fail item.
You have to remove the rear cover, the MFSYS and MCU board assembly to access that motor.
SOURCE: Out of fuser web.I need to reset it on nwm.How I
1.start +0
2.6789
3.dc135 hsfi line 20 clear
4.nwm accsess
6.read write
7.reset 3984 to 0,
8.reset 3985 to 0,
9.reset 3986 to 0,
10.reset 3987 to 0
Then open mashine door,take out fuser web sensor and put it back.
Message out of fuser is gone.Now it is ready to make copies.
How-to Fix KDS K917s Model 900P LCD Computer Monitor ...
? 9:59
https://www.youtube.com/watch?v=rkYJS2KhnTc
Jul 5, 2010 - Uploaded by X2YeZCAMCNC
How-to Fix KDS K917s Model 900P LCD Computer MonitorRepair Screen .... This screen has the exact ...
Amazon.com: Ac Dc Adapter Charger for Xerox Model 900 ...
www.amazon.com > ... > Monitors
Amazon.com, Inc.... Model 900 Xl592ds Xg-90d Xl370b Xl-370b Lcd Monitor,xerox Xg-70d 17" Lcd ...Power Supply FOR Xerox model 900 XL592DS XG-90D XG-70D XG-71D ...
SOURCE: how we solve the fuser moduleR3 temperature fault in the xerox machin of modul 5755
http://www.usask.ca/consumer_services/officecopiers/Replace_Fuser_Module_and_Ozone_Filter.pdf
if you have replaced the ozone filter also, ignore.
if not, shut down.
Generally most Xerox business volume machines tend to have power supply problems. The power supply can be repaired. Could be only a fuse or triad transformer. If you can remove the power supply yourself. Use a voltage meter to check continuity on the fuse or triad. You can also take it to someone to check it for you, say an electronics technician. If you purchase from Xerox I believe its rather costly.
