Question about Yamaha Boating
Where is the oil sensor unit on a 2011 Yamaha VXR waverunner
Anonymous
SOURCE:
Anonymous
  • 207 Answers
SOURCE: 2006 yamaha waverunner wont idle
what is it idle at? how much? remove your seat check air filter if is black oily remove it and see if that fixes your problem you may want to change your spark plugs as well # one cylinder may be starting to foul the new yamahas are the worst for fouling plugs use a cr8eb instead of the cr9eb the 8s are hotter and work better try those and let me know thank you
Posted on Jul 09, 2009
Anonymous
  • 948 Answers
SOURCE: yamaha waverunner excessive smoke
White smoke means coolant in the combustion chamber. Most likely a blown head gasket. You will have to tear the engine apart to be sure.
Posted on Jul 12, 2009
Anonymous
SOURCE: i have a 2001 yamaha waverunner and the gauges stop working
I have a 2001 waverunner and it stoped runing in the water . Now it will turn over but won't start
Posted on Jun 28, 2010
jurjmarian
SOURCE: how do I reset the code on a yamaha waverunner
How do I reset the code on dash board 99 yamaha waverunner 800?
Posted on Jun 06, 2011
Daniel
  • 123 Answers
SOURCE: 1989 yamaha waverunner. I purchased
Did you get any instructions from the previous owner? If it's a 4 stroke waverunner there will be a dipstick on the engine block, but I'm guessing it's probably a 2 stroke engine because most watercraft used 2 stroke motors clear through the 1990's. The oil will be mixed with the gasoline when you fill it, bottles of 2 stroke oil can be purchased at most stores that carry oil. Your waverunner can be mixed at 50:1, which equals out to be 2.6 oz of oil per gallon of gasoline. On a 2 stroke engine the engine gets lubrication from the oil mixed with fuel and will burn up fast if straight gasoline is used. Let me know if you have any troubles, but try to get ahold of the previous owner to get some more info.
Daniel
Posted on Aug 12, 2011
Is my 94 waverunner III gp a 2 stroke or 4 stroke
It's a two stroke .. Mix oil to gas before you add gas to your tank.
Aug 09, 2018 | Yamaha 2011 WaveRunner FX Cruiser SHO
This is for a Yamaha VXR waverunner 1994 troubleshooting electrical system need to verify charging system is working before replacing battery
With engine running disconnect the battery......if engine still runs the charging should be ok!
Aug 11, 2015 | Motorcycles
Yamaha waverunner
check for corrosion of the engine as leaving it for long any water left in the system will cause problems.
May 26, 2013 | Yamaha XL700Z Waverunner
Just changed the starter motor on my xl1200 limited 1999 and it's now making a grinding noise what should I do ?
U may have the wrong starter or it requires shims ( spacers) to adjust proper clearence.did u possibly drop or not see them when takin out?
Jan 09, 2013 | Yamaha Jet Ski Pwc Cover For Waverunner...
How we can charge the battery
what do you mean,does the alternator on jet ski not work?
Jun 29, 2012 | Yamaha Jet Ski Pwc Cover For Waverunner...
1989 yamaha waverunner. I purchased a 1989 25HP Yamaha Waverunner & was wondering how you check the engine oil?
Daniel
Aug 12, 2011 | Yamaha Superbike 1098 R Motorcycles
YAMAHA WAVERUNNER 2000 XL 800, WILL NOT RUN PAST 12 MPH
Have you done a compression test on all cylinders? My guess is you have a dead cylinder (no oil to one or more cylinders causing loss of power). If the compression test passes (all cylinders equal and higher than 100-110 psi) you have a restricted exhaust from a failed catalytic converter that has broken apart.
Apr 05, 2010 | 2003 Yamaha YZ 250
Boating Logo
65 people viewed this question
Top Yamaha Boating Experts
Colin Stickland
Colin Stickland
Mike
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
