Dehumidifiers Logo
Laurie DeWine Posted on Jul 11, 2018
Where do I get filter for Haier dehumidifier model DE45EK-T
1 Related Answer
Anonymous
  • Posted on Jul 05, 2011
SOURCE: Haier dehumidifier Model DE45EK-T--just bought.
It takes a couple if tries. Have to press it twice to get down low and have to have at high or low speed.
Haier DE45EK-l. Why does E2 code remain after cleaning?
Not familiar with this brand but all of them are fundamentally the same. If you cleaned with water, make sure the unit is thoroughly dry. Especially electronic components. Also..Make sure that the float for the water tank is correctly installed and not jammed. Some manufacturers set a E2 code for water collection tank issues.
Why won't it drain through the hose?
continuous drain option, So was there a plug in the end of pipe, did you remove it, does your pipe run down over, has to. Not a lot between bottom of unit and floor, But pipe has to go down over, if up and down, will not drain. down all the way
1helpful
I have lost my instruction manual and cannot change te temperature and humidity settings. How do you do this?
Here is a link to an Owner's Manual for a Haier 45 pint dehumidifier. Not sure if yours exactly like it or not, as you didn't mention a model number. You can download and print the manual for future reference.
http://www.haieramerica.com/cool-heat-air-quality/dehumidifiers/45-pint-capacity-electronic-control-115-volt-dehumidifier-de45ek-7
Look for the download in the left hand lower left on the page.
Hope this helps and thanks for choosing FixYa.
Haier 65 pt dehumidifier the lo light is on and the bucket is not fu;; and the filter is clean. ????
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Haier dehumidifier Model DE45EK-T--just bought. Displays E2. Power button not working--had to unplug to turn off.
2answers
I have a new DE45EK unit that has an error code E2. I powered it down for one hour and the code does not clear. First what is this code as it isn't listed in the guide that came with the product. ...
After turning the Master ON/OFF Switch to OFF, unplug the unit for the wall outlet and wait 12 -15 minutes. Then plug the unit back in to the wall outlet and turn the Master ON/OFF Switch to ON. That 12 - 15 minute timeout, should have allowed the unit to reset it self and clear that unknown code.
Since you are not having success using Haier's Customer Support Number, here's their email address
[email protected] <[email protected]>
Hope this helped you solve the problem.
3helpful
3answers
Haier 45 Pint Electronic Dehmidifier Error Code E2
Jason, currently the only 45 pint dehumidifier that Haier sell is Model # DE45EK or DE45EK-L or EK-T. If any of those matches the Model Number of yours, you can down load and print the Owners Manual from the link below. However, the model numbers I listed make no reference to Error Code E2. If your Model Number does not correspond to any of those numbers, your unit is probably no longer manufactured or available.
http://www.haieramerica.com/en/asset/product/4ba7175e54
With that said, there are two things you can do. First, turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12 - 15 minutes. Then, plug the unit back in and turn the Master On/Off Switch to ON. Did the Error Code clear itself. If so, set the controls as you normally would.
If that didn't solve the problem you can contact Haier Customer Service at 877-337-3639 and they will advise you what to do, to clear the error code.
Hope this helped you to solve the problem.
Top Haier Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
