Lands Phones Logo
Rona Watson Posted on Jul 11, 2018
I have a Panasonic KX-T7630 phone. Extension 22 has a permanent light on it and when I select it, I get a screen message with 'reorder tone'. How do I fix?
3 Related Answers
Anonymous
  • 6 Answers
  • Posted on Feb 12, 2008
SOURCE: kx-t7630 product spport
This is how I did it:
1. Press the 'Program' button 2. Then dial ** (star, star) 3. Enter the password (usually 1234) 4. Press 'Next' until you get to 'Ext Name' 5. Press 'Enter' 6. You will need to know the Extension Number of you phone, when you find out enter it (eg: 104 or whatever yours is) 7. Press 'Clear' to get rid of the old name then start entering the new name via the number keys. Note: If you keep cycling through the letter on each number you can get to lowercase or uppercase letters. 8. Press 'Enter' then you are all done... pick and hang up the handset.
cnavarro
Carl Navarro
  • 2460 Answers
  • Posted on Aug 26, 2008
SOURCE: I WANT TO PROGRAM THE
With any luck, you can get into programming from the main phone, or any phone programmed to have access by PROGRAM **1234. The soft keys will guide you, but you're looking for location 004 which is the namess for extensions.
At least that's the way it works on my 848.
Carl
cnavarro
Carl Navarro
  • 2460 Answers
  • Posted on Feb 17, 2009
SOURCE: Panasonic KX-T7630 Master Phone
Sure. It requires an Operating Manual (OM) and some programming. If you need the manual, here's a link http://public.carl.airpost.net/TDA/200_TDA_OM_06-12.pdf
On page 158 and 168 you can set up the features of the phone.
In order to do that, you'll go back to the phone that works, and press PROG and each button and write down what it says.
It will say things like EXT-102, LOG IN-100, VTR-165, etc.
If the buttons are labeled, note what it says, then move over to the phone you want to program. Press PROG, the button, then dial the codes from pages 168 forward for each function. It's not that difficult, for example, a DSS for ext 101 would be 1101 STORE, call log is 30100 STORE (or similar).
Each button changes when you press STORE and the feature will move if it has already been stored in another location. HOLD PROG backs you out of programming.
Please rate this solution or acknowledge that you have the manual if you need it as this link will be taken down when you do or by 2/23 if you don't..
Carl
7helpful
Hi, the incoming message red light is staying on. However all new incoming messages have been cleared. How do I fix this ?? Thank you DOnna
2 ways to clear this (most likely someone tried to intercom you and pressed the message button on accident instead of hanging up):
way #1:
1) press the "MESSAGE" button
2) on the screen it will display who turned on your message light
3) press the "CLEAR" button (third button from the left directly under the screen)
way #2:
1) press "INTERCOM"
2) dial " *700 " then your extension number (you will hear a confirmation tone)
3) hang up
Cannot go to voice mail to check my old voice mail from PANASONIC kx-t7630
If your old phone was an extension on the system and it is a TVA voice mail product, you dial the VM access code (usually 500) and when it answers you dial #6 * and your old extension.
You now appear as you would have if you had pressed MESSAGE or dialed 500 from your old phone.
Carl
Record a voice message on the oanasonic KX-T7630
the panasonic KX-t7630 doesnt have a answering machine and runs through voice mail.. if you have voice mail set up simple dial your number for voice mail (eg. 500) press 311, then record greeting at the end of tone. hope that helps
Don't know how to retrieve messages. (Extension is main switch)
Is that like when she says you have no new messages, To receive the messages press "1"? Press 1.
Carl
Message Lamp does not light
This will be a two step answer. Walk to any other extension and dial *701 plus the extension that doesn't work. If it lights the message waiting lamp (of course it will), then please look for your voice mail system cabinet. It may be black, with a dark blue cover the same as the TDA phone system. Part numbers would be TVA-50 or TVA-100.
If all of the above is true, you need to do some notification programming in the voice mail system. Do you have the programming software if it's a TVA?
Carl
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
14helpful
4answers
Message Light
Panasonic KX-T7630 , to turn off the message light when their are no messages do the following.... go to the phone that the light is lit up....push Sp-phone.... enter *700 and the ext number.That should take care of the problem. :-)
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
