SOURCE: Whirlpool Gold Accubake oven
depress the broil button for 5 seconds it will revert back to Farenheit
SOURCE: whirlpool accubake oven error code
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
It may just be a door switch
SOURCE: whirlpool Accubake Duo Oven Not Heating up
the oven not heating up. it's start up some time and other time u just hear it try to click on but don't hear no fire turn on
SOURCE: whirlpool oven accubake system
I have a whirlpool accubake wall oven. Half-way through baking a pie ,unknown to me, the oven went to the self-clean mode , the door locked and the pie started to burn. I tried to turn the oven off but it would not cut off. I immediately ran to the house's main power and turned off the oven breaker. I waited for a short time to let the oven cool enough to open the door and get the burned pie out, then went back to turn my breaker back on and the oven (even though in the off mode) started heating again with the bottom unit turning red again. I had to then go back and pull the power. We tried this several times trying to push the off button but the oven will not go off until we throw the breaker. Help please!
SOURCE: whirlpool accubake oven problem
I had the same problem and followed the process listed above....yes, I
did unplug/turn off the circuit and am alive to share this update!
Right off I noticed that the ribbon cable was loose. For those who have
tinkered around with other electronics such as a PC, etc., note that
this ribbon cable is not secured by the connector (atleast in my case).
Reseated the cable and turned the power on. Voila- the bake option
works. Tested it by turning it on for 20-30 seconds. Touched the bake
element and got proof that it was working fine (via a singe of the ring
finger ;-)).
About three minutes or so later, the display started to beep with an
error code - E0 F2. A shorted keypad is what it stands for. The clock
was still operable. I could still select the bake option, broil option,
etc. Ran a test bake cycle but it turned off after a minute or so and
started to display the E0 F2 code again.
Started the process all over ie turn power off, take panel off, reseat
ribbon cable. Turn power on and test by holding the Cancel button for
five seconds. Still displays the E0 F2 error. Waited for 10 minutes but
this time no more beeping or error display. Ran a preheat cycle for 4+
minutes without any problems. The oven warms up and the bake element
glows red. Hopefully, all is well. Will see what it does when we bake
something the next time.
Thanks to PropHeadTwo and others for their contributions.
