What are the specs of the RAM you added??
Testimonial: "thanks for your help .Rams are two 2GB Kingston 1333"
Hi again,
Have a read of this and see if it helps.https://www.howtogeek.com/310265/what-to...
SOURCE: I have a problem with my board Gigabyte
Do the fans still start spinning ? And did you do a CMOS clear ?
You should also try booting it without a graphics card and/or any other audio/network card, etc, so you only have the CPU and motherboard (and also try it with 1 RAM bank and without). When it beeps, it's probably alright (implicating other failing hardware).
When you hear no beeps at all (but the fans spin), it's pretty likely that the board is gone. You might want to doublecheck the powersupply and CPU nevertheless.
SOURCE: 8-9 bios beeps then shuts off restarts and more beeps
There is a problem of your devices attached to your motherboard, it could be the memory. Remove the memory card and then clean the pins with an eraser of pencil and put it back. Remove the graphics card and when the system boots then probably the graphics card is doing the problem but when the problem still persist then your memory card does the problem.
SOURCE: Dear Friends i
you need to flash the bios .
download the new bios from gigabyte website and follow their instructions on how to update bios. be very carefull when doing this because if done incorrectly it would render your motherboard useless permanently .
in my experience if your m/b is working its best not to update the bios only time i would update the bios would be if the new bios update has new features that i really needed . if not i would not really flash the bios .
SOURCE: My Gigabyte GA-G31M-ES2L Motherboard BIOS is
Try this link:
http://bios-repair.co.uk/bios/bsrecover.htm
SOURCE: GA-G31M-ES2L bios problem
Use CPU-Z from CPUID.com, Luke.
Will tell you what BIOS program, version, and date, you have now,
http://www.cpuid.com/softwares/cpu-z.html
Click on the Mainboard (Motherboard) tab for info on BIOS.
Need guidance in downloading, and installing CPU-Z post back in a Comment.
Regards,
joecoolvette
