First, I'm not a Memorex tech.
* speaker product info; https://www.amazon.com/Memorex-MW212RC-Wireless-Bluetooth-Speaker/dp/B00VJYWVAS/ref=sr_1_3?ie=UTF8&qid=1531097511&sr=8-3&keywords=memorex+wireless+bluetooth+speaker&dpID=41irUx8yT6L&preST=_SX300_QL70_&dpSrc=srch
* This one has a charger (but does not show the plug type) ; https://www.youtube.com/watch?v=tWTpQGSpoVU
* Memorex-FlexBeats MWB3363 uses an odd Apple cable; https://www.bestbuy.com/site/memorex-flexbeats-mwb3363-portable-bluetooth-speaker-gunmetal-gray/5763903.p?skuId=5763903
* Apple 3.3' Lighting to USB cable; https://www.bestbuy.com/site/apple-3-3-lightning-to-usb-2-0-cable-white/6652043.p?skuId=6652043
* This model uses a wall charger and if you check the "Answered Questions" There is a hint that it also uses AA batteries. (I suspect at least 4 AA batteries for estimated 6 volts); https://www.amazon.com/Memorex-Wireless-Bluetooth-Discontinued-Manufacturer/dp/B008X1C69G
* there should be a port to plug in the AC adapter cord. Check the ID plate for the power requirements (should be 6 to 12 volts DC). Take the speaker or take a picture of the plug socket and the ID plate. Check out your local electronics shop, Home Depot, Lowe's, or Best Buy and have there sales people find you the right charging plug.
* Sorry, can't seem to find a valid Memorex Support contact other than Memorex-Amazon.com
* Check the ID label for contact numbers or web site.
Aloha, ukeboy57
Go buy one fixya doesnt sell products
SOURCE: blue tooth adapter
Connect the headphones to the bluetooth.
Open the control panel, go to Sounds and Audio Devices.
Click the Audio tab.
Under Sound Playback (top portion of the tab), it says 'Default Device'. Drop the menu down and select your headphones. Click apply then ok, and you should be good to go.
I can't guarantee that this will stay set up this way. If you disconnect the headphones, you very well may have to run through this again.
SOURCE: Can a charger used for a blue tooth charge a sony
NO!
in NWZ series player ONLY can be charged when it's connected to PC or Laptop USB directly.no other way
SOURCE: my Just wireless blue tooth will not charge. I
i need to know voltage and apms for the charger of the just blue wireless BT-10K, your should use the same, could you email me the info at [email protected] please. it would be of great help.
Thanx alot, steve
SOURCE: Can I hook a blue Tooth speaker to my model #ld320ss8
I do not believe your model of TV has bluetooth support.
You will have to connect it with an auxiliary cable, or use other speakers with the appropriate cable.
You can use wireless speakers, but they would come with a receive that would have to be connect to the TV with a cable.
