Because when i took it apart the seal was on top of the bottom washer and to me that doesn't seem right because the seal isn't held in place but with it under the washer then the washer holds it in place
SOURCE: can't get spring back onto front seal that holds the seal in place
its very hard to do with the front on ,
if you have the top and bottom off you can keep trying
but removing the control panel and front is easier just a bit longer to do.
SOURCE: Lg WD8013f frnt load washer seal broken
The inner spring cable is a tough part to put back on without a special tool. You're best bet is to remove the front cover of the washer to try and reinstall the seal. If it doesn't work, you will need to call a qualified LG technician to help you.
SOURCE: replace valve stem oil seals
Make up an airline fitting that will screw into spark plug hole, or buy from autoparts , or tools supply place. You put compressed air in cylinder while changing, which holds valves in place.
SOURCE: i took my Mazda 323 1.6 engine at the Auto repair
Try this if you have rge 323 BG
Valve clearance - inlet: 0.30 c mm (cold)
Valve clearance - exhaust: 0.30 c mm (cold)
SOURCE: Kohler 1-piece flush valve seal replacement.
That is a tricky one. Tighten the tabs, twist into place, then tighten a bit more. They are a pain in the a$$, but with patience you will get it done. Good luck
Hi scottpage , I want to help you with your question, but I need more information from you. Can you please add details in the comment box? YO! Your great post is sadly located in "Question about Washing Machines"... I'm sure that's not what you wanted! Anthony
