Driver side front and back work perfect only passenger side front and back windows wont work
SEE this YOUTUBE FIRST!
Fix Jeep Cherokee Power Window and Locking Issues The RIGHT Way 1997 1998...
Then try this: "2004 jeep grand cherokee passenger door module"?
And this: "2004 jeep grand cherokee passenger door module location" (both on GOOGLE "IMAGES")
Disconnect your battery
Find these connections and CLEAN every contact.
Call The Auto Club (just kidding)
Anthony
(Say Thank You!)
SOURCE: power windows wont work
All things Capri are at //www.techcapri.com/
The manuals are there - check them out ...
Wiring diagrams are there. Probably fixed by now anyway.
Regards
Richrobi
SOURCE: power windows wont come up
try checking the switch that controls the up and down, I just had the opposite problem with my 2003 venture the window would not roll down, the garage put in a new switch for the part was about 75 dollars. it took about an hour to fix.
SOURCE: 2003 Buick Century - window problem
I've had a similar problem with my 2003 Buick Century. In my case, the driver's side front window one day went up and would not come down. I knew that the switch was malfunctioning by sticking in the up position since the window continued up despite the fact that Iet off the switch when the window was half way up and it continued going up. I had to pull over and pull the master switch assembly from the door panel and unplug it to prevent the window motor from being damaged by the constant power feeding it after the window was up. Basically, it would have burned the motor out. I cleaned the switch and it now works fine most of the time. I still need to replace the assembly. Not sure this is the reason in your case. I would check the back window and see if it goes down with the switch on the back door panel. If it does, then you are having problem with the master switch assembly on your front door panel. Moisture from rain from the window being down during rain or dirt may have corroded the switches' contacts.
SOURCE: my passenger side window wont work
Sounds like the window regulator is malfunctioning. The vehicle should still be covered under the manufacturers warranty.
