Microsoft HannsG HU171D 17" LCD Monitor Logo
Posted on Aug 02, 2009
I have a monitor HANNS-G It worked 3 years. And exactly after 3 years warrant policy ended my monitor got a problem. It looks like there is a problem in power connection on front buttons. After I connect a power cord to power outlet the green light power is blinking, the monitor doesn't get light screen and stay black. I need to keep it in this position several hours and at last the screen turns on and I can use monitor normal way. If I do not turn off computer and keep it working (no safe method or screen off ! ) my monitor stay working. If I turn off computer for about more than 1 hour and turn it on later, the monitor again does not light on for a long-long time.
Anonymous
Level 1:
Scholar:
  • Contributor 31 Answers
  • Posted on Aug 02, 2009
Anonymous
Contributor
Level 1:
Scholar:
Answers
31
Questions
0
Helped
12296
Points
68
This is a problem with the power supply unit inside the monitor, there is no easy way out here. If you keep on using your monitor like this eventually it won't switch on no matter how long you wait. Keep on using it like this for the time being without switching off anything but ultimately you will have to take it in for repairs or otherwise purchase a new screen..
I have Hanns G 22" lcd monitor. Would like to know what the size for the 3 screws that attach the stand to the monitor are, please? I had it wall mounted for the last couple years and lost the screws. I...
Best guess, since they all seem to be different as i have access to two Hanns brand monitors and both are a different size, its most likely a 4, 5, or 6mm. The only way to find out for sure is get some screws and try it, just pay attention to the length, too long and it might not tighten up or damage something internally. They are usually pretty short, looking at the ones i have i would say the screws are maybe 8mm in length max.
2answers
How to open Hanns G 28" monitor.
3 screws across top and 2 in lower images?q=tbn:and9gcszcucatuwbsigg82atflilcifasvtk3ai5_wt5czzf6sn7tgq_0q3 screws across to and 2 in lower corners
if this helps please take time to rate
1helpful
Please tell me where find drivers for my monitor "Hanns-G,HU196D" i dont find this. Please send me or write me links directly. Thanks and good luck.
Monitors don't need drivers, video cards do. You will need to find out your exact model of video card by running this program:
http://www.piriform.com/speccy
then go to the site of its manufacturer and you will find its exact driver there, in the Downloads section.
1helpful
Screen has gone very fuzzy all
Try another known good working monitor on your computer, if the screen looks good then you know the monitor is bad. If the known good working monitor looks fuzzy as well then you know the video card is bad on it and would need to be replaced.
1helpful
Help make speakers work
raggedyan184 -
You can find the driver for your monitor here:
http://www.howtodrivers.com/model501390.html
(You will have to enter in the numbers shown above the "Download" button in order to download, security measure for the site)
The following instructions (from the site) are also listed for installation:
Step-by-step guide for install HANNS.G HU171D driver.
1. Download file for HANNS.G HU171D from our site, save it on your computer and unzip.
2. Connect your HANNS.G HU171D to computer.
3. Right click on My computer and click Properties. Go to Hardware tab. Click to Device Manager button.
4. Find your new HANNS.G HU171D on Lcd monitors category double click on device and press Reinstall Driver button.
5. Select Install from specific location, check Include this location and click Browse button to select the Hanns.gdriver click Next button to continue and click Finish button to finish installation.
6. After this procedure you should see new HANNS.G HU171D in Lcd monitors inside device manager.
Hope this helps!
-- RT
PS - If this was useful, don't forget to vote!
1helpful
I-inc CY199 monitor will not turn on
It sounds like you have a monitor with a common problem, we have repaired many Hanns-G monitors with this problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you can't do the repair we offer a repair service, contact us for more details.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
2answers
My Hanns-G hw191d monitor quit coming on. The green light at the side is on, indicating that it is receiving signal from the computer, but nothing displays on the screen. Is there a fix, or should I just...
First, flip the switch for your power surge protector, to see if that resolves. Then, test the monitor on another computer and see if it works. If the monitor still doesn't work, look for another one. Hope that helps.
My hanspree hf289h monitor has recently started to flash its menu on the screen times between the flashing menu and the time it stays on the screen vary. I tis about 3 yrs old
The older Hanns G monitors had there flukes, contact Hanns G about the issue, there is no physical fix. They will be able to help you. The new Hanns G screens are amazing, i had 3 of the 28" screens off newegg! :)
2answers
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
