Electrical Supplies Logo
Becky Hoyle Posted on Jul 06, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wolf generator wont power up - Electrical Supplies
Generator Guru Parts
Level 3:
Master:
  • Electrical S... Master 286 Answers
  • Posted on May 29, 2020
Level 3:
Master:
Answers
286
Questions
Helped
148803
Points
1274
Hi!
The vast majority of the time it is the AVR failing. If they fail they will show about 5v on the voltmeter when you run the engine.(if more than 5v please contact us.) Replacing the AVR should fix the problem.
Also, Check the AVR Brushes are making full contact, if not replace. These do wear over time and will not excite the generator if contact is not being made.
Parts are available here: https://www.generatorguru.com/wolf-wolf-power-wolf-professional/
On rare occasions, if you have had faulty equipment attached or overloaded it for a prolonged period of time, it could have damaged the alternator. This is often partnered with an electrical smell and/or smoke coming from the alternator.
If you need any further help, have a look at our help centre. If the answer is not there we will get you assigned to a generator engineer who specialises in your generator.
https://www.generatorguru.com/need-help/
Kind regards,
The Generator Guru Team
sherlywang
Level 3:
Master:
  • Electrical S... Master 428 Answers
  • Posted on Apr 11, 2020
sherlywang
Level 3:
Master:
Answers
428
Questions
0
Helped
198438
Points
1063
The generator does not operate in accordance with the specified technical conditions, such as too high stator voltage, iron loss increases; if the load current is too large, the copper loss of the stator winding increases; if the frequency is too low, the cooling fan speed becomes slow, affecting the heat dissipation of generator; the power factor is too low, so that the rotor excitation current increases, resulting in the rotor heating. Check whether the indication of monitoring instrument is normal. If it is abnormal, necessary adjustment and treatment must be carried out to operate the generator in accordance with the specified technical conditions.
www.dieselgeneratortech.com
3 Related Answers
thesnooper
  • 342 Answers
  • Posted on Apr 04, 2010
SOURCE: Wolf 800 generator. Engine will run but very electrical power is
is the engine running at the correct speed
3000 rpm to produce 50hz
3600 rpm to produce 60hz
Anonymous
  • Posted on Nov 18, 2011
SOURCE: ENGINE STARTS, BUT NO POWER IS GENERATED TO THE
Try this website and youtube video, should help:
http://www.generatorguru.com/
http://www.youtube.com/watch?v=tC_LrrZcx38&feature=player_embedded
rmarkjameson
Roger
  • Posted on Dec 02, 2016
SOURCE: grade of engine oil to use in a Wolf Generator WP2200
grade-engine-oil-use-in-wolf-generator-gbvrtbitjkf22dtuggw4chck-1-0.jpeg Here is the Oil for the WP1200 and WP2300
Can you get replacement circuit board for wolf 2300lr power generator
Hi.
I would think so.
Contact Wolf google wolf generators in your country.
Good luck.
2helpful
Hi we have a wolf 950 generator that wont start,cleaned plug,is there anything else i can try,HELP!
are you getting spark. pull out your plug and with the wire connected. hold the plug about an 1/8 of an inch away from any metal on the motor and ensure your getting spark. also check to ensure your fuel is not bad..
3helpful
No spark at plug
I have a coleman pm 2200 about 12 yrs. old. No spark
Top Electrical Supplies Experts
Sean Wright
Sean Wright
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
