I have a Kenmore Upright Freezer model #25320402002 that I bought about 12 years ago. I need the weight of the unit please. I cannot find a spec sheet anywhere. Thanks!
SOURCE: Kenmore® (46-26072) Elite® 20.6-Cu. Ft. Frost-Free White Upright Freezer
Check these two things first. 1. Is there a thick frost buildup on the back panel at the bottom half of the freezer? 2. Do you hear the fan running inside the freezer? Let me know what you find.
SOURCE: problem with upright freezer not freezing
It sounds like the unit is low on freon or the compressor is going bad. You have several other components that could be affecting this as well. Make sure the coils are free from dust and clean underneath. This is a bit premature for you to have problems now, especially since it is a Sears product.
SOURCE: FREEZER ALARM WILL NOT SHUT OFF
You can try 2 things. Unplug it for about 2-3 minutes and then replug it. It should reset itself. You can silence the alarm or muffle it. Silencing it should be hard. Disconnect it from its source. You may want to find out why it is alarming constantly. Have you called Sears and asked them?
SOURCE: Hot exerior walls in a brand new Kenmore 28042 upright freezer
There should not be a fire hazard but you should be concerned that the freezer could break down if it is not allowed to vent the heat it produces. The freezer is not intended nor designed to be enclosed The manual must indicate specifications for minimum clearances for rear, top and sides, and may even be indicated on the big yellow sticker on the inside of the door. The clearances must be respected or again, the unit will fail, and the warranty may be voided in such cases.
SOURCE: Kenmore upright freezer alarm sounds constantly
replace the battery in the grill or the hi-voltage control under the unit in the back
