SOURCE: manual for LG TU550
Hi here is your manual
http://au.lgmobile.com/web/web.support.manualRF.laf
any more help required please let me know.
Take care
SOURCE: vista compatable software for LG TU550 mobile phone
right click on properties
just run the program in compatability for xp
installs just fine
SOURCE: LG tu550 and Windows XP professional
If you want to use a cable connection, go into the phone menu and select the following:
Menu > Settings > Connectivity > USB Connection Mode > Mass Storage
After this, plug the phone in via the USB cable.
The computer will prompt to install the modem driver which you can cancel.
Then the computer should detect the memory card as a USB drive and you can copy and paste what you need.
Hope this helps
SOURCE: Need Boost SIM card to work in Nextel Motorola Buzz+ ic602 phone.
I called Boost support about the same issue and I was told that that particular phone and any other Ic series phone by motorola will not work with Boost Mobile. There was also a few other phones that will not work. Try calling thier support line and requesting the list of phones that won't work. Good luck.
SOURCE: How do I unlock my LG TU550 phone? Where can I get
At&t will provide you with the subsidy unlock code for this phone at their customer service number at 1-800-331-0500
